Help to chose AVR + speakers for $900 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2013, 10:54 AM - Thread Starter
bodosko's Avatar
Hi, I want to upgrade my old SONY STR-DE897 + SA-VE566H speaker kit.
My budget is $900 or tight tight $1000.
I'm in doubt if I get a 5.1 or 7.1 system because of my limited space for surround.
You can see in this pic: https://www.dropbox.com/s/wr4biyv80u3skmo/2013-01-22%2013.51.58.jpg
The AVR doesn't need to have much sources. I will just use it for Set-top box, PS3 and PC via HDMI with DTS, AC3 etc...
bodosko is offline
post #2 of 2 Old 01-25-2013, 06:07 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
If you want some replies you should post in the speakers forum. You'll get crickets in here.
Afro GT
afrogt is offline
Reply Home Theater In A Box
