Can I use the rear speakers in 2.1 on the HT-S3500? - AVS Forum | Home Theater Discussions And Reviews
Old 01-23-2013, 04:33 PM - Thread Starter
Mark Kramer's Avatar
I have the Onkyo HT-S3500 5.1 Sound System.
What I want to do is force the back speakers to do the same thing the front speakers are doing when it's playing 2.1 sound. Is there a setting for that? It seems pointless to only use two speakers when the rear ones could easily be being used as well.
2.1 just sounds so one-sided.
Mark Kramer is offline
Old 01-23-2013, 04:36 PM
Louquid's Avatar
Liked: 38
Does your receiver have "Multi-Channel Stereo" as a surround option? That is basically what you're wanting.
Louquid is offline
Old 01-23-2013, 06:03 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Or, use something like PLII, that will intelligently route sound to the surrounds, more like you'd get with a 5.1 source.
BIslander is offline
Onkyo Ht S3500 5 1 Channel Home Theater Speaker Receiver Package
