Need help on Getting Audio to come threw TV and getting Sp Config to be available as a option - AVS Forum | Home Theater Discussions And Reviews
Old 02-08-2013, 07:25 PM - Thread Starter
fat tone's Avatar
Have a question for those who have this system already. How do you get the Audio to come from the TV without a cable box? HDTV is a Sony KDL-46EX400. Have OTA antenna.
Other question I have is how do I get the Sp Config option to turn on. Its not Highlighted in The Options?
Any help would be greatly appreciated.
fat tone is offline
Old 02-09-2013, 02:19 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
You'll get more responses in a thread for your TV, I would think.
BIslander is offline
Old 02-09-2013, 11:10 AM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
The simple answer is to connect your antenna to the Ant/Cable input on your tv. That's how I have mine setup. Turn on your tv speakers. Using the internal ATSC tuner scan for OTA channels. If you have a HTS system, then connect an optical cable from your tv to the receiver. Turn off the tv speakers, set the audio to external, pick the source on the receiver, and listen to 5.1 audio thru your HTS system if the program has it (most OTA stations do).
Otto Pylot is online now
