got no sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-12-2013, 05:35 AM - Thread Starter
barney101's Avatar
anyone help, ive emailed panasonic but nothing back, i have a panasonic viera 42" hd tv. ive just bought a panasonic sound bar (sc-htb20) connected and double checked i have the wires in the correct places, with hdmi in the arc slot and still i have no sound from the bar, power light is on the sub woofer...???
barney101 is offline
post #2 of 3 Old 02-12-2013, 08:19 AM
Otto Pylot's Avatar
Quoted: 1629 Post(s)
Liked: 1024
Are both devices ARC capable? Try an optical cable out from the tv to the soundbar (if it has an optical in).
Otto Pylot is offline
post #3 of 3 Old 02-12-2013, 09:20 AM
Possumgirl's Avatar
Liked: 58
Assuming your TV supports ARC, be sure you have VieraLink enabled and that your speaker settings are set to home theater.
Possumgirl is offline
Reply Home Theater In A Box
