onkyo ht-s3500 won't output full HD video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-14-2013, 01:31 AM - Thread Starter
iElessar's Avatar
Hello.
I just got my Onkyo HT-S3500 (ht-r391 receiver) but there is a problem. It does not show any signal with full HD.
I have:
PS3
Xbox 360
Wii U
Blu-Ray Player
All are connected to the AV receiver via HDMI. Sound is output fine and I can hear it just fine. However, video does not show if my devices are set to Full HD 1080p.
When I configure my Xbox 360, PS3, or Wii U to 480p, I get video signal. However, when I setup them to output 1080p the screen goes black.
As for the blu-player, I can't get any video signal since it runs 1080p by default and I cannot configure it with a lower resolution.
Even setting them to 720p results in the same issue.
And this is the TV I'm using - http://www.lg.com/za/tvs/lg-47LV3710-led-tv
I've also tried a factory reset, still no luck.
What's the problem here? And how can I fix it?
Thanks in advance.
iElessar is offline
post #2 of 5 Old 02-18-2013, 06:15 AM
mikepier's Avatar
Quoted: 16 Post(s)
What happens when you hook up the devices directly to the tv? Did you try a different hdmi cable to output to tv?
mikepier is offline
post #3 of 5 Old 02-18-2013, 09:28 AM - Thread Starter
iElessar's Avatar
If I have my sources configured to 1080p, the TV goes black telling me no signal. I can only hear audio.
Yes I tried swapping HDMI cables and all of them result in the same problem. I even got a replacement from the dealer, same thing.
Setting them to 1080i works fine though.
iElessar is offline
post #4 of 5 Old 02-19-2013, 11:37 PM
ohioviper's Avatar
To my knowledge the only one of those that can do 1080P is the PS3.
ohioviper is offline
post #5 of 5 Old 02-20-2013, 04:57 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Is that when connected directly to the TV, per mikepier's question? If so, the problem would not be the receiver.
BIslander is offline
Reply Home Theater In A Box
Onkyo Ht S3500 5 1 Channel Home Theater Speaker Receiver Package
