Newbee question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 86 Old 02-25-2013, 10:08 AM - Thread Starter
420 benz's Avatar
I have an Onkyo HT-S590 and a Samsung 8000 series Smart TV. I am connected to a Direct TV DVR via Optical cable from the TV to the top optical input on the receiver. I also have an optical cable. Also an optical cable from the receiver to the DVR. My problem is that when I opt to view a movie on Netflix,I can not get Netflix to play in Surround Sound. All TV Channels work just fine through V2 on the receiver.I have spent hr's playing with all of the inputs on the receiver but to no avail. Need help.
420 benz is offline
post #2 of 86 Old 02-25-2013, 10:37 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
May be that Netflix does not send 5.1 or the optical out put from the set is only stereo. try using some other listening mode. check page 46/47 in owners manual. The DirecTV DVR does output 5.1 if available in there content. an easy test is try off air tuner and see what you get.
Phil17108 is offline
post #3 of 86 Old 02-25-2013, 10:45 AM - Thread Starter
420 benz's Avatar
This problem happened when I moved the TV from a console to the wall. That's when this problem started. It worked great before.
420 benz is offline
post #4 of 86 Old 02-25-2013, 05:59 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
420 benz first posted this issue in the Surround Music forum and a couple of us couldn't get him to a solution. To clarify what I think his situation is - Netflix comes from his TV and he only hears sound from the TV speakers, not from his sound system.
http://www.avsforum.com/t/1459868/newbee-question#post_23006874
BIslander is offline
post #5 of 86 Old 02-26-2013, 09:27 AM - Thread Starter
420 benz's Avatar
That is not completely true. I only here SS from the TV but when the TV is playing a Netflix movie. No mater what I change on the Receiver V1-V2- V3 nothing will put Netflix through the Receiver. The only way to hear Netflix is through the TV speakers. Regular TV programs will play in SS on V-2.
420 benz is offline
post #6 of 86 Old 02-26-2013, 09:44 AM - Thread Starter
420 benz's Avatar
BTW: Everything you guys told me to do like assigning TV to different inputs on the Receiver works BUT it is only for the TV.
What I don't understand is since Netflix is coming from the TV why won't the sound come through the Receiver.
420 benz is offline
post #7 of 86 Old 02-26-2013, 10:27 AM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
If it worked as you say it did when it was mounted on a console, and the only thing you've done is wall mount it, then it sounds like something may have gotten damaged in the process if you have it cabled exactly the same way it was when you had it on the console.
Otto Pylot is offline
post #8 of 86 Old 02-26-2013, 11:41 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
When you say "works BUT only for the TV", are you referring to Direct TV programs? If I understand how you have things connected, the audio from Direct TV does not originate on the television set. Rather, it comes from the DVR and is atttached to the receiver as Optical 1, which is assigned to V2 on the receiver input selector/remote. Meanwhile, in your other thread, you said Netflix originates on your Smart TV, but you only get sound from it through the TV speakers. Is that correct?
post #9 of 86 Old 02-26-2013, 02:24 PM - Thread Starter
420 benz's Avatar
YES.
420 benz is offline
post #10 of 86 Old 02-26-2013, 02:46 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
OK. So far, so good.
Is the cable from the TV plugged into Optical 2?
If so, what receiver input selector is assigned to Optical 2? See p35 of the manual, which explains how to find that information. (The chart on p35 shows the default assignments, which you may have changed at some point. So, you need to see which AVR selector name is currently associated with Optical 2 before proceeding.)
post #11 of 86 Old 02-26-2013, 03:03 PM - Thread Starter
420 benz's Avatar
There is an HDMI cable from TV to DVR an optical cable from the (only opt.output ) DVR to one of two outputs on the receiver. By using the directions on page 35 V2 is dedicated to SS. But it only works with TV programs.
420 benz is offline
post #12 of 86 Old 02-26-2013, 03:23 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
OK. The HDMI cable from the DVR to the TV should not affect anything. It is used to feed video to the TV. (The HDMI audio output could also drive the TV speakers if you didn't want to use the sound system. But, that's not what is happening here.)
So, what about the questions I asked re: the optical cable from the TV to the receiver? That's the next step in this process.
btw, the DVR and TV have optical OUTPUTS. The receiver has optical INPUTS. And to avoid confusion about your devices, please refer to the actual equipment rather than talking about sound from "TV programs". In other words, when you select a show on the Direct TV set top box, you get audio from the receiver speakers. But, when you use Netflix on the television set, you get audio from the TV speakers and not from the receiver speakers.
post #13 of 86 Old 02-26-2013, 04:02 PM - Thread Starter
420 benz's Avatar
That is correct. I put a program on the TV. Then I put a movie on Netflix. Sound only comes from TV program. Now if I turn on the receiver the SS comes from the TV program not Netflix.
420 benz is offline
post #14 of 86 Old 02-26-2013, 04:06 PM - Thread Starter
420 benz's Avatar
The only way to here Netflix is through the TV speakers.
420 benz is offline
post #15 of 86 Old 02-26-2013, 04:14 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Let's try again. Please answer these questions:
Is the cable from the TV plugged into Optical 2 on the receiver?
post #16 of 86 Old 02-26-2013, 04:24 PM - Thread Starter
420 benz's Avatar
That cable I set to V2 as per page 35. The CD button works on V2 (only for the TV).
Like I said before there is no optical input dedicated to V2.
420 benz is offline
post #17 of 86 Old 02-26-2013, 04:33 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
That doesn't answer he questions I asked. Let's start with the first question only.
There's an optical cable from the television set output to a receiver input. Which receiver input is it, Optical 2?
post #18 of 86 Old 02-26-2013, 04:36 PM - Thread Starter
420 benz's Avatar
V2
420 benz is offline
post #19 of 86 Old 02-26-2013, 04:44 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
V2 is not the physical input. V2 is the selector name that can be associated with several different inputs. So, I am asking which of the two physical inputs on the back of the receiver has the optical cable from the television set. It has to be either Optical 1 or Optical 2.
post #20 of 86 Old 02-26-2013, 04:53 PM - Thread Starter
420 benz's Avatar
I am such an idiot. I just pulled both Opt. Cables out and after cleaning the inputs I found a 1 and a 2.The Opt. Cable from the TV is in Opt.
420 benz is offline
post #21 of 86 Old 02-26-2013, 04:54 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Opt. ???
post #22 of 86 Old 02-26-2013, 04:58 PM - Thread Starter
420 benz's Avatar
Opt. 1
420 benz is offline
post #23 of 86 Old 02-26-2013, 05:02 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
So, which receiver selector input is assigned to Optical 1? That's the chart described on p35 of the manual. (Again - the chart in the manual shows the default assignments. We need to know the actual assignments as yours may be different from the defaults.)
post #24 of 86 Old 02-26-2013, 05:17 PM - Thread Starter
420 benz's Avatar
I don't think it is assigned to anything.
420 benz is offline
post #25 of 86 Old 02-26-2013, 05:22 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
That could explain why it is not working. Try assigning Optical 1 to "Video 1/VCR"
post #26 of 86 Old 02-26-2013, 05:34 PM - Thread Starter
420 benz's Avatar
Still no SS on Netflix.
420 benz is offline
post #27 of 86 Old 02-26-2013, 05:44 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
So, to confirm...
1. The optical cable from the TV set is plugged into Optical 1 on the receiver.
2. You have assigned Video 1/VCR to Optical 1.
3. When you select V1 as the source on the remote, what do you get?
p37 of the manual explains how you can display the format information of the audio arriving on an input.
post #28 of 86 Old 02-26-2013, 05:46 PM - Thread Starter
420 benz's Avatar
Why is there a V3 when there is only two Opt. Inputs? Is V3 for component -composite cables.
420 benz is offline
post #29 of 86 Old 02-26-2013, 05:54 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Let's leave that until later. For now, what audio format arrives on V1 when you play Netflix on the television set?
post #30 of 86 Old 02-26-2013, 06:05 PM - Thread Starter
420 benz's Avatar
3. It says Video 1 46 (volume )
When I press Receiver + Multi Ch I get DVD + 46
When I press Receiver + Display I get Video 1 then V1 + listening mode
420 benz is offline
Reply Home Theater In A Box
