What do you guys think of this setup for a $2000 budget? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-06-2013, 09:09 PM - Thread Starter
albert0373's Avatar
I know there are other threads for a similar budget, but just looking for opinions on this proposed setup and if everything will work in tandem with each other.
These are just price estimates right now, will be purchasing in a month so will be looking for deals. Add in two speaker stands, wires/cables, etc and that should hit my $2k budget hopefully.
Should I get dual subs?
Klipsch Reference RW-12d 12" Powered Subwoofer $350
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
Polk Audio New Monitor 75T $500
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290272
Polk Audio Monitor Series CS2 Center Channel Speaker $170
http://www.amazon.com/Polk-Audio-Monitor-Channel-Speaker/dp/B0002MPNLC
Polk Audio TSi100 Bookshelf Speakers $180
http://www.amazon.com/Polk-Audio-TSi100-Bookshelf-Speakers/dp/B00192KF12/ref=pd_sxp_f_pt
Denon AVR-1713 5.1 Receiver $370
http://www.amazon.com/Denon-AVR-1713-Networking-Receiver-Outputs/dp/B007R8U5W6''
albert0373 is offline
post #2 of 3 Old 05-07-2013, 08:57 AM
flickhtguru's Avatar
Liked: 110
You should have posted this in the speaker section since this is not a HTIB.
IMO if you like those speakers this is what you should get.... 75T towers, 25C center, 35B surrounds, those are all the speakers in the New Monitor series and all match eachother. And yeah dual RW-12D subs would also be good.
Shawn
flickhtguru is offline
post #3 of 3 Old 05-07-2013, 02:29 PM - Thread Starter
albert0373's Avatar
Thanks! I'll cross post over to the Speakers section
Reply Home Theater In A Box
