Unable to bitstream HD from my HTIB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-06-2013, 10:59 PM - Thread Starter
tezz99's Avatar
Hey guys
I have read through these forums many times to get help, but today, i am forced to create a thread for help of my own. I apologize if i have posted in the wrong section, but I need help.
I just purchased an intel nuc ethernet version. I got xbmc set up and audio seems to work fine with analog. I have a 5.1 receiver which can decode both dts audio andd dolby digital audio.
When i set it up with wasapi audio for both pass through and out put with dts audio and dolby digital audio enabled, everything seems fine but it makes me need a second remote to control audio. I don't want this. So i disabled dts audio aand dolby digital audio so the nuc decoded it itself.
This is making video fps go very very low. AND THERE IS NO SOUND. WHY IS this? Is there a fix? Please help
5.1 audio is only working with wasapi enabled with dts audio and dolby digital audio. Please help me
Intel nuc has 2hdmi. 1 going into sony bd-e280 which is connected to speakers and the other goes to a panasonic. I only run xbmc on one screen as the 2 displays are extended. My default device is set to the Sony avamp as in the picture below.
And only these 2 supported formats are shown:
I tried with another computer by plugging in the BDV-E280 via hdmi. Once again only 2 of these are supported. Is it a setting that i have selected incorrectly? Please help me. If you look at the pdf link below you of the BDV-E280 Specifications, you can will clearly see DTS HD and Dolby Digital HD bitstreaming is supported by my system.
http://www.docs.sony.com/release/specs/BDVE280_mksp.pdf
Cheers
Tezz
tezz99 is offline
post #2 of 4 Old 05-10-2013, 10:18 PM
razotong's Avatar
Sony HTiB does not support HD Audio bitstreaming, other than direct play from a disc http://pdf.crse.com/manuals/4265164131.pdf - see page 61
Best out of that box with xbmc I think will be DTS and DD, no point in trying anything else - as multi-channel LPCM isn't supported throught HDMI either, solution is to buy a receiver that passes through HD Audio
razotong is offline
post #3 of 4 Old 05-11-2013, 05:00 AM - Thread Starter
tezz99's Avatar
At the moment i am going to stick with this receiver and pass through dd and dts. I dont really know whats so great about HD anyway :P
tezz99 is offline
post #4 of 4 Old 05-11-2013, 05:35 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
What sources would you have from your computer with lossless audio? The HTIB has a Blu-ray player which does lossless just fine.
BIslander is offline
Reply Home Theater In A Box
