How does the Yamaha YHT-399U compare to the Sony HT-SS380? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 02-06-2015, 07:21 PM
Otto Pylot's Avatar
Quoted: 1368 Post(s)
Liked: 854
Thanks. Good to know.
Otto Pylot is online now
post #62 of 65 Old 02-07-2015, 03:43 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
Just a heads up, this sub is huge compared to the Yamaha one. Also, fairly heavy at 45 lbs. However, if you have the space I would highly recommend it. If not, the SUB-1000 (10 inch) should be the next best thing.
PlasmaPZ80U is offline
post #63 of 65 Old 03-01-2015, 01:13 PM - Thread Starter
Liked: 562
I thought I make a quick list of the changes I've made since last December that have together greatly improved my audio system/setup:
1. changed front LCR to Sony Core speakers (cost: $260 plus tax)
2. changed subwoofer to Dayton Audio SUB-1200 (cost: $130 plus tax)
3. turned off EQ and set subwoofer crossover on AVR to 120 Hz
4. moved surrounds so that surround effects come from the correct directions, speakers are facing main listening position, and SL/SR balance is preserved (still not 100% perfect but the best I can do at the moment without major room layout changes and/or possibly significant expenses on new furniture/speaker stands/wall mounting)
5. optimized subwoofer placement (basically in the same spot as before but much closer to the corner to maximize output and angled to avoid obvious nulls)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
post #64 of 65 Old 03-01-2015, 01:16 PM - Thread Starter
Liked: 562
The main change I have left is to pick a pair of bookshelves/surround speakers and at the moment, I'm discussing it here:
Micca MB42X vs. Infinity Primus 143 vs. Boston Acoustics SoundWare (4.5 inch version)
and some earlier discussion here:
Upgrading (5.1) Speakers from Yamaha HTIB, Many Questions...
post #65 of 65 Old 03-01-2015, 01:25 PM - Thread Starter
Liked: 562
Also, I found the adaptive dynamic range control setting (Adaptive DRC) to be more useful/effective than the main dynamic range setting. The latter only works for bitstream audio signals and has two fixed levels of compression (standard and minimum/auto). The former is continuously variable based on volume setting (the higher the volume setting, the lesser the compression; the lower the volume setting, the greater the compression) and it works for bitstream and PCM audio signals.
Reply Home Theater In A Box
Yamaha , Sony Ht Ss380 3d Home Theater System 2 Hdmi Cables Surge Protector , Sony , Sony Brand
