Additional speaker output to Bose v35 - AVS Forum | Home Theater Discussions And Reviews
Old 05-26-2013, 09:09 PM - Thread Starter
jramku77's Avatar
I have a Bose v35 which is connected to its jewel cube speakers via the sub woofer. I also have a Russsound A-Bus system which allows audio output to be played in other rooms via non-Bose speakers. The Russsound system takes audio input using an RCA Jack. The question is: How do I take an audio output from the v35 and connect it to the Russsound RCA?
The existing audio outputs only go to the Bose speakers. I can't find any other audio output from the v35.
Any thoughts are appreciated.
jramku77 is offline
Old 06-01-2013, 03:49 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
I'm afraid you know what I'm about to tell you: sell the Bose and get yourself a regular receiver with analog RCA multi-zone outputs and some better speakers. Bose is quite proprietary in its connections, so you're stuck with their equipment if you want to expand anything... besides being a Ford Pinto wrapped up in a Toyota Camry marketing campaign (with the sticker price of said Camry).
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Old 06-01-2013, 04:44 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
^^^^ unfortunately I'd have to agree with that. Bite the bullet, dump the Bose, and start looking around.
Otto Pylot is offline
Old 06-01-2013, 08:39 PM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
I have to agree with both Dan and Otto. Dump Bose and get a new system.
steve1971 is offline
Old 02-02-2015, 03:22 PM
mrbill1155's Avatar
Liked: 0
Audio output from Bose V35
I read this on a post Hope it helps.
AngryStamen - I have a Bose V35 system with about 8 addon SA3/SA2 amps that feed speakers in various rooms in my home and a connection to my PC.
Like you have said, to get sound OUT of your Bose V35 or V25 to non-Bose equipment (like your inwall speaker system which I assume are driven my an inwall amplifier that you will hooking to the Bose system) you do need the Bose link 9pin DIN to 2 connector RCA males cable.
To get sound over the connection you need to tell the Bose system to send music over the cable. For this you need to buy and use the Bose RC-35S2 remote control (you can get one on ebay for about 65 bucks (sometimes more, somtimes less). the room switches need to be configured as room O.
When your remote is configured, the remote will allow you to turn on and off the signal to the amplifier feeding your speakers and allow you to control what source is sent (e.g TV, FM/AM, Disc, IPOD). You can not, however control the volume of the signal that goes to the amplifier - it is only a line out. If you already have a volume control you are all set. if not, you may need to add an inline volume control or preamp.
You could also use an HDMI splitter on the V35 output. and add an HDMI to component/audio converter. then what ever sound is being played on the main speakers would be replicated on your inwall speakers. I use an HDMI splitter to send my V35 output to 2 different TVs - work great
hope this helps
mrbill1155 is offline
Old 02-02-2015, 07:27 PM
Otto Pylot's Avatar
Liked: 852
Oh No Mr. Bill You responded to a post that's almost 2 years old. I think the OP has moved on.
Old 02-03-2015, 12:20 PM
mrbill1155's Avatar
Liked: 0
Yes, the OP , not to be confused with Otto Pylot , of course, probably has moved on. I am a frustrated Bose owner and grasp at any information that can be helpful, even if it is very old, so I thought I'd chime in.
Old 02-03-2015, 02:22 PM
Otto Pylot's Avatar
Liked: 852
Have you thought about getting a new audio system?
