Help...Yamaha Rx-A800 receiver to Sony Blu Ray Sound Issue - AVS Forum | Home Theater Discussions And Reviews
Old 05-27-2013, 01:39 PM - Thread Starter
laurenf's Avatar
Hello-
This is the first post on here. I hope I am going about this the right way. I have recently hooked up my Yamaha receiver to my Sony Blu-Ray, and I am only getting the background sound. I can't hear any of the voices or speaking. The receiver works with my Samsung LCD TV, and the sound is fine. I have two Bose speakers hooked up to the receiver. The TV and the Blu-Ray are hooked up through an HDMI cable to the receiver. Please let me know what the problem could be. I can't seem to figure it out. Hopefully, it is just a simple fix.
Thank you!
laurenf is offline
Old 05-27-2013, 03:45 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Do you only have the two speakers? if so, have you configured the receiver that way? With 5.1 sources, most of the dialog is in the center channel. By configuring the AVR as a 2.0 system, it will send the dialog to the two front speakers.
BIslander is offline
Old 05-27-2013, 09:32 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
Your TV works fine because it is sending a 2 channel signal. You have to configure your receiver for a 2 speaker setup. Then all audio will be sent to the front speakers.
make sure center, surrounds and subwoofer are all set to OFF or NONE if there are no other speakers connected.
Afro GT
afrogt is offline
