Onkyo vs Yamaha - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-02-2013, 05:41 PM - Thread Starter
Jammers10's Avatar
I'm looking to upgrade my home theater system. Of these two brands which has the best home theater systems? I've heard good things about both companies.
Jammers10 is offline
post #2 of 14 Old 06-02-2013, 07:10 PM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
Both of them are good (I have a Yamaha) but I'd suggest deciding on what features you want and configuration (separates, HTiB, etc). Pick a system that meets those needs, and then listen to it if you can. Best is a relative term.
Otto Pylot is offline
post #3 of 14 Old 06-03-2013, 05:27 PM - Thread Starter
Jammers10's Avatar
Do you have a Yamaha HTIB? If so what model?
post #4 of 14 Old 06-03-2013, 06:24 PM
Otto Pylot's Avatar
Liked: 852
Yes. I bought the YHT-395 a little over a year ago. The receiver is the RX-V371. Works extremely well for our environment. and has plenty enough power and options for us. The speakers are ok but they will be upgraded in the future. I believe the new model is the YHT-397 (which has the RX-V373 receiver).
post #5 of 14 Old 06-03-2013, 11:30 PM
PlasmaPZ80U's Avatar
Quoted: 1960 Post(s)
Liked: 559
The 399 is the new one
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #6 of 14 Old 06-04-2013, 09:36 AM
Otto Pylot's Avatar
Liked: 852
post #7 of 14 Old 06-04-2013, 10:23 AM - Thread Starter
Jammers10's Avatar
How about the YHT- 799 and YHT- 599? Are they not the newest models? They seem to be a bit more expensive but i'm willing to pay a little more if need be.
post #8 of 14 Old 06-04-2013, 11:09 AM
Otto Pylot's Avatar
Liked: 852
I'm not familiar with those. Just compare the specs and see if it's what you want/need or is more than you need at this time. The Yamaha receivers, in my experience, are well made and should serve you well for as long as you need it to.
post #9 of 14 Old 06-04-2013, 12:00 PM
Liked: 559
the latest models end in 99, last years end in 97 (and the year before that 95)
post #10 of 14 Old 06-04-2013, 12:04 PM
Liked: 559
http://usa.yamaha.com/products/audio-visual/hometheater-systems/home-theater-package/?selected=453028_453026_453021_&mode=compare
post #11 of 14 Old 06-05-2013, 11:27 AM
siersema's Avatar
One thing to look for is how the remote is programmed. I found out after purchasing the RX-V677 that the power is dedicated Power On and Power Off commands. There is no Power IR command that will toggle the current condition to the other - if power is on , click power would turn it off; if power is off, click power and it would turn on. That meant that several generic remotes would not work to turn the unit on and off.
siersema is offline
post #12 of 14 Old 06-05-2013, 02:20 PM
Otto Pylot's Avatar
Liked: 852
A Harmony remote will resolve that.
post #13 of 14 Old 06-09-2013, 04:10 PM
Liked: 559
is this why when I program my comcast remote for my yamaha HTiB the volume up/down and mute buttons work but the power button does not? the receiver is the HTR-3066, part of the YHT-399U
post #14 of 14 Old 06-09-2013, 06:07 PM
Otto Pylot's Avatar
Liked: 852
^^^^^ that could very well be. My old Harmony 880 works great as a single button "what do I want to do?" kinda remote.
Reply Home Theater In A Box
Yamaha Yht 395bl Complete 5 1 Channel Home Theater System , Yamaha Rx V373 5 1 Channel Av Receiver , Yamaha Rx V371bl 5 1 Channel Av Receiver
