Help with compact system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-09-2013, 01:51 PM - Thread Starter
horseplay's Avatar
You would think with so many speakers systems out there I will have no trouble finding what I need, but no. I think what I need is fairly common. I have a 50 inch panasonic plasma the sound quality is horrible. I do not have the TV hung on the wall so I cannot put a sound bar under the TV. Plus I do not like the sound from them.
So here is what I need. I need a stereo system that can be used for the TV. Center speaker will be a plus but I am not that picky. I need some reasonable small stereo speakers + wireless sub + a build in receiver + bluetooth. The Bose Cinemate system seems to be what I need but I does not have a wireless sub nor bluetooth. Are there any system out there I have overlooked? I want to fairly simple and compact system. I know some of the sound bars have bluetooth + wireless sub but I like a little better separation between the left and right speakers plus the placement problem mentioned before.
Please help me out ....
horseplay is offline
post #2 of 3 Old 06-11-2013, 11:05 AM
evgeshais300's Avatar
evgeshais300 is offline
post #3 of 3 Old 06-13-2013, 04:15 AM - Thread Starter
horseplay's Avatar
I find this before reading your reply. Looks like just what I need if the sound quality is stable. I have a Panasonic tv so the viera link will be a big plus. Ordered last night. Can't wait to set it up.
Sent from my ADR6350 using Tapatalk 2
Reply Home Theater In A Box
