5.1 Output from my Sony BRAVIA KDL-40EX403 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2013, 08:52 AM - Thread Starter
Gingerboi's Avatar
Hi all,
Need some help please. Complete novice here!
I have a Sony BRAVIA KDL-40EX403 which only outputs 2 channel audio via the optical out regardless of whether the original input was in 5.1 or not (Sony confirmed this).
According to http://www.sony.co.uk/product/tv-102-40-lcd/kdl-40ex403 it outputs in 5.1 but can't find out how. Would this be via Hdmi1?
Looking for a new home theatre system and want to know if its worth buying one that has Audio Return Channel enabled.
Steve
Gingerboi is offline
post #2 of 2 Old 06-23-2013, 09:47 AM
Possumgirl's Avatar
Liked: 58
All HDTVs will output 5.1 from the TV's internal tuner (antenna connection). Most will NOT output 5.1 from source devices connected to the TV. Since this is a European model, best to take the word of Sony support. Whatever audio the TV outputs, it would be the same whether you use optical or ARC.
Possumgirl is offline
Reply Home Theater In A Box
