Suggestion on Home cinema speakers - AVS Forum | Home Theater Discussions And Reviews
Old 07-03-2013, 12:16 PM - Thread Starter
rocky001's Avatar
Hi All,
I am new to this forum. Thinking to setup a home cinema at my home. I have a big spare room which I am thinking to have a home cinema setup. I felt the hall is huge.Below are the dimensions
Hall width 17.5ft
Hall Length 25ft
Hall Height 8ft.
[*] I am thinking about either Benq w1070 or optomo hd 25 projector.
[*] I am also thinking to go for remote or manually operated Elite screen (model number not yet decided).
[*] I am stuck up here. Not sure which speaker sound system to go for and which woofer to choose.
I have gone through KEF speakers and woofer systems, Bowers & Wilkins loudspeakers options and
Monitor audio speakers so far . My budget together for speakers and woofer is around 2400-3000 .
Based on the size of the hall and budget ,If anyone can suggest me about speakers and my choice of projector,that would be great.
Thans you so much in advance.
Much appreciated.
Rocky
rocky001 is offline
Old 07-03-2013, 02:13 PM
Otto Pylot's Avatar
Quoted: 1369 Post(s)
Liked: 857
You might want to post your question in the Speakers forum. It is a more specific area for you question and there are lots of very knowledgeable folks there (not that there aren't knowledgeable folks here but it's more of a relevant area).
Otto Pylot is online now
