How can I get more sound out of the sub in my Samsung HT in a box system? - AVS Forum | Home Theater Discussions And Reviews
Old 08-27-2013, 09:34 PM - Thread Starter
DustyMonkey1's Avatar
I have the the Samsung 7.1 home theater in a box system, model number HT-D6730W. The sub SUCKS. I barely get any bass out of it at all. It's on the highest setting volume level. It seems that all my bass is sent to my front speakers. How do I correct this? How do I prevent bass from being sent to the front speakers?
DustyMonkey1 is offline
Old 08-28-2013, 05:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
According to the user manual
http://downloadcenter.samsung.com/content/UM/201202/20120202154053712/HT-D6730W_XAA_web_1226.pdf
page 35 says that there is a separate volume control for each speaker. Have you turned up the volume control for the subwoofer?
According to page 36, there is an automated calibration faclity.
Have you tried it?
arnyk is offline
Old 08-28-2013, 09:26 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Do what Arnyk says above and then dump that subwoofer, it's not very good.
I think you have 3 different threads about the same thing. you've got a 6" passive sub that doesn't play very low.
Replace the subwoofer with a powered sub!
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
Afro GT
afrogt is online now
Old 08-28-2013, 10:26 AM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
^^^ can he replace it? Doesn't the D6730W have an integrated blu-ray player which means that his passive sub draws its power from the blu-ray player. The wiring diagram looks like the speaker cables are proprietary and not universal (binding posts).
Otto Pylot is offline
Old 08-28-2013, 11:05 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Yes, the receiver/BD player unit lacks a RCA jack for a powered subwoofer. The speaker terminals are proprietary which means that the best way to connect a third party sub would be to butcher the subwoofer cable and turn it into a pigtail.
If you had a powered sub with speaker level inputs, it might be possible to connect that pigtail to the powered subwoofer via them. The power drain on the receiver/BD player would be minimal.
arnyk is offline
Old 08-28-2013, 11:24 AM
Otto Pylot's Avatar
Liked: 853
^^^ I figured there was a way to "modify" the cables but I wasn't sure about the "feeding" of two power sources to the sub and how that would, or could, affect playback. Never gave it too much though because I never had to deal with it. Is it possible to do what you suggest without affecting the audio output?
Old 08-28-2013, 11:50 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If one power source is the AC line and the other is a speaker connection, then there is no problem.
arnyk is offline
Old 08-28-2013, 12:57 PM
Otto Pylot's Avatar
Liked: 853
Ok. That makes sense. So there is no power sent to the existing sub via the proprietary connection or some circuitry that senses the passive sub and tells the Samsung that a sub is connected and to push the audio?
Old 08-28-2013, 02:20 PM
afrogt's Avatar
Liked: 755
No, I think its just plain speaker wire with a connector on it to make it easy for new HTIB users to avoid using bare wire.
I'm pretty sure he can just cut the wire and insert the bare ends into the subwoofer speaker terminals.
I still think he should just buy a real receiver whether that's now or a few months down the road. I cant stand HTIB systems like this.
Afro GT
Old 08-28-2013, 04:08 PM
Otto Pylot's Avatar
Liked: 853
Thanks for the added info. That's what I like about these forums, there's always something new to learn or to add to the old database wink.gif
I agree about the integrated systems. They sound good on paper.... Even though I have a HTiB I made sure the receiver did not have a built-in Blu-ray player and had 5-way binding posts as speaker terminals and a single sub cable out (among other requirements). Receivers seem to last longer than speakers so the ability to easily upgrade to what ever I want was a necessity.
Old 08-28-2013, 06:29 PM
afrogt's Avatar
Liked: 755
I don't know if I agree with that. I've got some 20 year old speakers in one setup. 20 years ago you couldn't get a Dolby Digital 5.1 or DTS receiver let alone anything with HDMI.
Afro GT
Old 08-28-2013, 09:30 PM
Otto Pylot's Avatar
Liked: 853
That is very true and maybe I shouldn't have been so general in my post, but it seems that a lot of of folks who ask questions here don't have the "age" advantage that some of us have.
