Home theater system for movie room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-29-2013, 05:32 PM - Thread Starter
oileruis's Avatar
Hi guys,
This is my first post in this comunity (and so far, i missed a lot of good info coming from here) and i would like to know which one will be a good 5.1 or 7.1 home theater system (or receiver and speaker separately) for a 21'6" x 13'8" room. I am planning to set up a dedicated "cinema" with a good projector (i will ask about the projector in other forum smile.gif ) and a couple of good seats. I heard that Onkyo, Bose and Yamaha are good options
Which will you recomend below 2000 usd budget?
Regards!
oileruis is offline
post #2 of 4 Old 08-30-2013, 06:37 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
With a good budget like yours, I would recommend buying the pieces separately rather than getting an HTIB. You can get an excellent receiver for $400-500, leaving plenty for speakers and a sub. For receivers, Denon, Marantz, Onkyo, Pioneer, and Yamaha are good brands to check. Speakers are more a matter of personal taste in both sound and appearance.
oileruis likes this.
BIslander is offline
post #3 of 4 Old 08-30-2013, 08:19 AM
afrogt's Avatar
Quoted: 1090 Post(s)
Liked: 782
With a $2K budget you need to post this in the Speakers or Receivers forums. since most of the money will be spent on speakers post it there.
The HTIB forum gets way less visitors and hence less responses.
By the way Bose is not a good option unless you want to get less bang for your buck.
Afro GT
afrogt is offline
post #4 of 4 Old 08-30-2013, 08:24 AM - Thread Starter
oileruis's Avatar
Thank you for the reply..i will change the post.
oileruis is offline
Reply Home Theater In A Box
