TV, radio, iPad, WiFi on audio9.1 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-29-2013, 11:25 AM - Thread Starter
LGsmart's Avatar
How can I simpliest connect my TV (it has optical output + HDMI) to listen powerful music/films on 9.1 speakers ?
I wanna also listen to FM radio (does receivers with "normal" radio still exist:) ?
Also connect some android/iOS phone or tablets wirelessly to this 9.1 spekers ?
Maybe on this equipment to play also some internet, youtube (oh, I can make this by TV), or some other apps.
And the sound not to be too bad. And of course I dont wanna spend 5000 € for these smile.gif
In 1990s we used Tehnics, Yamaha apmlifiers with cinch and SCART conectors - what sort of equipment is used nowadays ? Should I use "solution in a box" or some separate components (like we did in past: receiver, radio, kasette, gramophon, cd) ?
LGsmart is offline
post #2 of 2 Old 09-30-2013, 08:48 AM - Thread Starter
LGsmart's Avatar
I indeed dont need 9.1 - it is just largest number I saw in specifications:)) As I understand situation now, best for me is to build my Theather centre component on component, like we used to do in 1990s smile.gif not buying "in a box"
If I understand corectly first I need to get AV receiver with HDMI(ARC) and Optical-IN (at least 5 of them all togehter, or do you suggest even more ?), AV receiver which also has internet capabilities and posilibilty of wifi connection from android/iOS devices.
And for not getting in one-way street to early, I suppose it is best to choose such AV receiver which has all sort of (5.1, 7.1, 9.1, dolbyXY) support, so I will not need to exhange it for another 30 years.
(and connect my old speakers, CD, gramophon on it - later swicthing it with more nowadays component: 3D bluray, etc. ?)
If anybody can give me some URLs of such AV receivers under 900€, I will be very glad. Thanks.
Which speakers would you suggest to me for under 100€ / peace, and to be very good, and very stylish. Should I go wireless?
One of best I saw around are these from Samsung 2.1 in a box system HT-FS5200:
http://images.samsung.com/is/image/samsung/uk_HT-FS5200-XU_510_Dynamic_black?$Download-Source$
but I am just afraid theirs sound is bad frown.gif didnt hear them yet!
My wife would be very pleased with them, as she would think they are
vases smile.gif)
LGsmart is offline
Reply Home Theater In A Box
