Need a simple setup for 25 feet x 15" 9' room - AVS Forum | Home Theater Discussions And Reviews
Old 10-04-2013, 02:30 PM - Thread Starter
GreenDroid's Avatar
I need some help with a setup, I plan to buy a VIZIO M651 from Costco and I will have it set in a 25 feet x 15" 9' as indicated in the diagram below with a Sofa around 8 feet away from the TV for good 3D.  My wife forbid me from using wire on the floor (even minimal).  I love a 5.1 systems, but I would never hear the end of it from my wife.  So I need advice.
**The Philips HTL9100 seems to fit the need, but I saw bad review from you guys
**The Bose 1SR is really expensive, but could it work in this big room? It does have the corner and 2 walls to bounce sound of
**Yamaha YSP-3300 for the same price as the Bose seems to have way more functions
Any other system? that would give me close to a 5.1 system?  I would prefer not to cut hole or something  Oh and the floor is hard wood.  I don't know if any other options are there.
                                 25 feet
____________________________________________
|        15" 9'
|                    Sofa
|    TV(65 inches)
_____________________________________________
GreenDroid is offline
Old 10-04-2013, 04:40 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
This is a great place to start http://www.sonos.com/shop/products/playbar
It can be expanded to a wireless 5.1 system by adding a subwoofer & rear speakers ( not completely wireless, the additional speakers plug into AC wall outlets ).
Dropkick Murphy is offline
Old 10-04-2013, 06:34 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
I don't see any mention of the Sonos system being a true, discreet 5.1 system, unless I missed it. Adding multiple speakers doesn't necessarily make it a 5.1 system. And it's expensive!
Otto Pylot is online now
Old 10-05-2013, 05:22 AM - Thread Starter
GreenDroid's Avatar
I realized that a true 5.1 would be almost impossible with being not able to run wires on the floor.  I just need something to come as close as possible.  The Philips seems to come come close, but I saw some bad review from you guys.  Also the size of my room also concern me as it is too large I think for bouncing sound around.
Also saw Yamaha YSP-3300 for the same price as the Bose seems to have way more functions.  Any other options guys?
Old 10-05-2013, 10:35 AM
Otto Pylot's Avatar
Liked: 853
I'm sure there are true 5.1 systems with wireless side channels. As mentioned before, there will always be some wiring because both speakers need to be plugged into an outlet for power, or at least one has to and then the two are connected together with a cable of sorts. The wireless part comes from the fact that the speakers are not connected to the receiver. Unless you absolutely can't, I'd steer clear of a soundbar and look for a wireless receiver. You'll be much happier with the sound quality. At least imo.
