Simple 2.1 System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-06-2013, 08:44 PM - Thread Starter
Jer446's Avatar
Hello,
I am moving into a small NYC apartment and am looking for a new sound system. 5.1 won't work because wiring would be too complicated. I think a 2.1 system would suit my needs. Mostly TV/Movies and some music when I have friends over.
My budget is $300. Towers would be great, but I don't know if I can get them in my price range.
PS. Best sub $900 60"+ TV?
Jer446 is offline
post #2 of 5 Old 10-06-2013, 09:14 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Good approach. How about start with 2.0 with a set of Cambridge Audio S30s and add a sub down the line? You will want a 10-12" sealed sub, which for quality will set you back over $300 - so no need to jump in now.
lespurgeon is offline
post #3 of 5 Old 10-07-2013, 11:47 AM - Thread Starter
Jer446's Avatar
Thanks. That could be an option. Would I be better off getting a simple sound bar, or should I not even bother?
Jer446 is offline
post #4 of 5 Old 10-13-2013, 03:52 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Except for the higher-end soundbars, decent bookshelf speakers have sounded better than anything in the sub $300 range that I have heard, but I haven't been looking hard.
post #5 of 5 Old 10-14-2013, 07:14 AM
Tarheeltom's Avatar
Tarheeltom is offline
Reply Home Theater In A Box
