Broken BTT-370 BluRay player - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2013, 03:36 PM - Thread Starter
tsuroku's Avatar
Hi,
The bluray player that came with my btt370 system is no longer working. Apparently I can't buy the player alone, so I was wondering if it'd be possible to connect the speakers to another player or A/V receiver.
If so, could anyone give me some tips on how to do this, or what kind of systems I can use?
Would it be possible to plug the speakers to an amp?
tsuroku is offline
Old 10-14-2013, 04:10 PM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
A lot of all-in-one HTiB have special speaker connections so it's difficult to connect different speakers to the main unit or vice versa unless you do some wire splicing. The subwoofer is usually passive in these systems (deriving its power from the blu-ray player) so connecting it to a standalone receiver, while not impossible, may be a little difficult and the resulting sound would be less than desireable. You might want to look at another HTiB without a built-in blu-ray player because speakers can be upgraded very easily if need be and the subwoofer will more than likely be an active sub which will give you much better bass response. Then just get a separate blu-ray player and you're all set. Ideally, it would be best to buy separate components instead of an HTiB but if money is tight, you can get some very nice systems from Yamaha, Onkyo, and Denon.
Otto Pylot is online now
