HELP!! Consfused with options for home theater!!! - AVS Forum | Home Theater Discussions And Reviews
Old 10-15-2013, 03:19 PM - Thread Starter
echvee1's Avatar
Hi,
I've been using Bose LS12 for last 10 years, but after reading lot of reviews and advise, I'm planning to stay away from Bose and try something else.
I'm leaning towards following for the home theater that I'm putting together. My room size is 12 x 16. I'll be mostly playing movies for my home theater system.
1. Goldenear Triton Seven OR
2. Martin Logan Electromotion ESL OR
3. Martin Logan MLT-1, 5.1
I'm leaning towards MLT-1 because of it's price point ($379 on amazon).
Can you please suggest:
1. Which system would be idea for movie experience in the room that I have above?
2. And which receiver can I use with this set-up?
How about GoldenEar and Electromotions? Which receiver for these?
Thanks in advance for your suggestions.
echvee1 is offline
Old 10-16-2013, 07:05 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
You're trying to compare $2000/pr Martin Logan ESL speakers to cheap MLT-1 satellites? That's not even a fair battle.
You're also in the wrong forum, you should post this in the speakers forum where you'll get more responses. ESL's do not qualify for Home Theater In a Box speakers.
What's your budget, do you even have one? And how much are you willing to spend on a receiver?
Afro GT
afrogt is offline
