Onkyo ht-s5500 - can you control the start up source ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-25-2013, 12:06 PM - Thread Starter
bobbee25's Avatar
I just bought the Onkyo ht-s5500, nice sound.
If the receiver is off and I turn on the TV, the receiver will come on, but it always automatically starts with the TV/CD selection. Hence no sound.
I did something and was able to get the video with either the TV/CD or Sat/Cable buttons, but no audio with the TV/CD.
It would be great if when the TV is turned on the Onkyo would come up on in the Sat/Cable input (Which is the TV) or if I could get the sound with the TV/CD.
Ideas appreciated.
bobbee25 is offline
post #2 of 7 Old 10-25-2013, 01:27 PM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
Harmony remote. I do exactly that with OTA. When I tell the Harmony to "Watch TV, the receiver turns on to the appropriate input as does the tv. If I tell the Harmony to "Watch Movie", the receiver turns on to the appropriate input, the blu-ray turns on, and the tv turns on as well. Switching between the "sources" is just as easy. When I turn off the Harmony, all devices turn off.
Otto Pylot is offline
post #3 of 7 Old 10-25-2013, 02:08 PM - Thread Starter
bobbee25's Avatar
Which Harmony would you recommend ?
bobbee25 is offline
post #4 of 7 Old 10-26-2013, 04:35 PM
Otto Pylot's Avatar
Liked: 1043
I have an old Harmony 880 that works great. Harmony One seems to be a decent remote (albeit a bit pricey). You might want to ask in the Remotes Forum for detailed info.
post #5 of 7 Old 10-28-2013, 05:29 AM - Thread Starter
bobbee25's Avatar
Sometimes when the Onkyo is shut off and I turn on the tv, I can use the tv speakers. But it appears inconsistent.
Whenever I turn on the Onkyo and select the Sat/Cbl the Onkyo sound works.
There isn't any consistency with the tv sound when I turn on the TV, Onkyo is turned off..
Turn on just the tv, no sound.
Turn on the tv and tv sound works.
(I ordered a Harmony 650)
bobbee25 is offline
post #6 of 7 Old 10-28-2013, 07:39 AM - Thread Starter
bobbee25's Avatar
bobbee25 is offline
post #7 of 7 Old 10-28-2013, 09:08 AM
Otto Pylot's Avatar
Liked: 1043
The 650 is a nice entry Harmony. It's limited to 4 devices I think, so if you have more than 4 devices to control you'll have to choose which ones you want to operate with the Harmony.
Reply Home Theater In A Box
