LG HB966TZW Home theatre system stuck on boot. Can i use LG speaker with another receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-05-2013, 07:14 PM - Thread Starter
I've had the LG HB966TZW for about 2 years now. I know its not perfect but it did its job, until recently it was stuck on
"PLEASE WAIT" and would never boot.
Now its outside warranty so LG wont recovgnise it as a fault. They referred me to get it fixed at TECH1 Miranda.
I haven't been able to find any information online about this problem to fix it myself.
I don't really wanna pay to get it fixed if i could just ditch it for a good receiver. My question is could i use the wireless speaker
system with another brand of receiver?
Milan Zorman is offline
post #2 of 6 Old 12-09-2013, 05:47 AM
Alireza12321's Avatar
Hi,
I am having the same system with the same problem. did you manage to fix your player?
Alireza12321 is offline
post #3 of 6 Old 12-09-2013, 11:25 PM - Thread Starter
yeah i sent in for repairs and it cost me 250
post #4 of 6 Old 12-09-2013, 11:30 PM
That's very expensive, but I might need to do the same.
Thanks a lot for your help.
post #5 of 6 Old 12-10-2013, 03:54 AM
did they tell you what was wrong with it?
post #6 of 6 Old 01-02-2014, 03:29 PM
adnank's Avatar
Hi ,
I have the same system "but not wireless" HB966tz and I have the same problem .
In LG service center I saw many devices have the same problem , I thought at first it is maybe a firmware problem but the technician couldn't confirm and he told the they reported the problem to LG .
Shame on LG , if it is a general problem they should fix it by free or replace the device .
Any way , I am thinking like you to use the speakers with another AV receiver , the speakers power are 180w and 4ohm impedance but with AV receiver you need a powered sub woofer as the sub came with LG is passive .
Unfortunately in my country we don't have much choices , I think Yamaha is still have some models
Any other idea from you guys should help
adnank is offline
Reply Home Theater In A Box
