Is my sound quality lacking becuase of this setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-23-2014, 10:13 PM - Thread Starter
agtjamesb007's Avatar
I have an ONKYO home theater system. My setup was a dvd player, plugged into the tv via HDMI and a digital optical cable directly from the dvd player to the receiver. The receiver does not have any HDMI inputs (or outputs). The receiver would select the appropriate sound format from the dvd (Dolby PL II or what not)
Now I purchased a blue ray player for a few blue rays and netflix streaming capabilities. However it only has an HDMI out on the back. So now I plug the HDMI directly into the tv (as I have done with the dvd player) but for audio, I plug the digital optical cable directly into the tv from the receiver instead of into the blue ray player. Will the receiver not select the appropriate sound format from the blu ray now that it is plugged into the tv instead of the blu ray player itself?
agtjamesb007 is offline
post #2 of 10 Old 01-24-2014, 07:33 AM
scorrpio's Avatar
Depends on TV.
See this thread, it describes a situation pretty much identical to yours (HDMI only Blu-Ray and no-HDMI sound system)
http://www.avsforum.com/t/1513666/question-about-my-surround-sound-not-sure-what-connection-to-use-for-tv
scorrpio is offline
post #3 of 10 Old 01-25-2014, 10:08 PM - Thread Starter
Thank you, that thread was a help. I think i may look into a different blue ray player. Now in choosing one I am thrown off with all the decoders listed. The blue ray I am looking for has Dolby True HD decoder. If I play a blue ray or dvd that was filmed in Dolby Digital, or Pro logic II, will have poor sound quality becuase it was not filmed in Dolby Ture HD? Do the decoders have to match up on the blue ray player and the reciever? I am new to this and it can be very confusing.
post #4 of 10 Old 01-25-2014, 10:11 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
if you're not connecting your blu ray player directly to a AV Receiver with HDMI you'll never get TrueHD audio anyway.
Afro GT
afrogt is offline
post #5 of 10 Old 01-26-2014, 01:18 AM - Thread Starter
well I am now. I am either going to up grade my player or get an audio extractor.
post #6 of 10 Old 01-26-2014, 10:16 AM
afrogt's Avatar
Liked: 761
An audio extractor? Does your receiver have 7.1 analog inputs?
It would be easier to buy a receiver with hdmi and true hd decoding.
Afro GT
afrogt is offline
post #7 of 10 Old 01-26-2014, 01:05 PM - Thread Starter
No the receiver does not have 7.1. I love it, its fantastic, I just happened to get it right before they started putting HDMI input/outputs on them. All I have to do is make sure any device I buy I can hook up separately via Digital optical or coaxial and Im good to go.
post #8 of 10 Old 01-26-2014, 01:17 PM
Otto Pylot's Avatar
Quoted: 1371 Post(s)
Liked: 857
Optical can not pass Dolby TrueHD (or any other lossless format) untouched. The best it can do is discrete 5.1. Just because you can hear audio from all 5 speakers doesn't mean that it's TrueHD.
Otto Pylot is online now
post #9 of 10 Old 01-26-2014, 10:10 PM
afrogt's Avatar
Liked: 761
You can get a HDMI receiver for under $200. If TrueHD and DTS-MA are important to you then get a new receiver.
Afro GT
afrogt is offline
post #10 of 10 Old 01-27-2014, 09:30 AM
flickhtguru's Avatar
Liked: 110
OP the best thing you can do is get a new receiver. Check out accessories4less.com for discounted prices on receivers because they are refurbished. I own refurbished products and honestly I won't buy brand new products because my pockets aren't deep enough to get what I want. If your upgrading your receiver you may want to go with a 7.2 receiver to give you some upgrade possibilities and definitely get a receiver with Audyssey Auto Room EQ. Maybe something like the Onkyo TX-NR626 or similar. Or if you can find an Onkyo 616 or RC470 for a good price grab them. I just got my aunt and uncle to buy the RC470 a few weeks ago from accessories4less.com it was a $650 receiver brand new, they paid $285 for it refurb.
Shawn
flickhtguru is offline
Reply Home Theater In A Box
