best surround sound for optoma hd25e - AVS Forum
Old 03-03-2014, 05:56 PM - Thread Starter
aeropg's Avatar
Looking for a great sound system for my projector. Help me choose
aeropg is offline
Old 03-03-2014, 07:10 PM
Otto Pylot's Avatar
Quoted: 252 Post(s)
Liked: 272
Budget and room size would be helpful.
Otto Pylot is offline
Old 03-03-2014, 07:13 PM - Thread Starter
aeropg's Avatar
No more than 300 medium size room don't have sq footage.
Sent from Galaxy Note 3
aeropg is offline
Old 03-03-2014, 08:40 PM
Otto Pylot's Avatar
Quoted: 252 Post(s)
Liked: 272
You could probably get a refurbed entry level system for $300 or less (even though the speakers will probably be marginal).
Old 03-04-2014, 01:06 PM - Thread Starter
aeropg's Avatar
Plugged in an older subwoofer and surround speakers I have but no sound was coming from the speakers. I changed the default sound to audio 1 and then 2 still no sound. My projector has its own speakers I can t seem to get it working. I am using hd25e dont want to spend money on surround sound speaker set if it will not work
aeropg is offline
Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector
