New to HT, want to put theater in house im about to move into. Need help/suggestions of what sound system I should put in (pics/specs in post) - AVS Forum
post #1 of 5 Old 04-07-2014, 12:36 PM - Thread Starter
ODirty's Avatar
Hey guys,
Like it says, We are about to move into a different house and my father and I are going to make one of the rooms in the basement a dedicated theater room. We have never done this before.
That being said, I would love any suggestions you guys can give.   Also,our budget for a projector and sound system is about $2500.
I was thinking about getting this system off amazon: http://www.amazon.com/dp/B00DUFJWA6/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1VV4S3K55UBN3&coliid=I1PIAY2KP1TGVE
Room Specs: 17ft long, 13ft 3in wide, 7ft 6in ceilings:   http://imgur.com/a/Fe4P8
(We wanted to put a raised stage in the back and another row of theater style seats in front of that) Here is my crappy rendering
http://imgur.com/2iQ6Jng
Any suggestions?
ODirty is offline
post #2 of 5 Old 04-08-2014, 09:05 AM
crazyrob425's Avatar
Quoted: 136 Post(s)
Liked: 171
Little bit extra money will get you more
http://www.amazon.com/Klipsch-RB-41II-Theater-System-Onkyo-TX-NR626/dp/B00DTL7ZFU/ref=pd_sim_sbs_e_4?ie=UTF8&refRID=0FMCYK4QKS0X562AX6PQ
crazyrob425 is offline
post #3 of 5 Old 04-08-2014, 11:40 AM - Thread Starter
ODirty's Avatar
Wow you are right.
Any other suggestions guys? I think we have decided on the PJ we want to get and its about $900. So that leaves us about $1600 to spend on a sound system. Need some suggestions.
ODirty is offline
post #4 of 5 Old 04-08-2014, 12:07 PM
Quoted: 136 Post(s)
Liked: 171
Post a thread in the Speaker section (http://www.avsforum.com/f/89/speakers) stating your $1,600 budget and they will recommend you the many options available.
post #5 of 5 Old 04-08-2014, 12:29 PM - Thread Starter
ODirty's Avatar
Just did! thanks
ODirty is offline
Reply Home Theater In A Box
User Tag List
