Help hooking up TV, Cable, HTIB PLEASE!! - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By JChin
post #1 of 19 Old 08-23-2014, 06:47 PM - Thread Starter
thuggy1111's Avatar
Ok so heres my hardware
I have a shaw HD digital cable box
5.1 CH Samsung 3D Blu ray surround system HTF-5550 surround system
Samsung UN60F7100 60-Inch 1080p 240Hz 3D HDTV (TV has an HDMI1 STB and HDMI2 ARC)
xbox 360
xbox one
My current setup is working minus the xbox 360... moved to a new house and before we moved i had everything going fine including the xbox 360 working off the receiver so im not sure what boo boo i made. Any help appreciated !!
Current setup:
HTIB HDMI OUT >> XBOXONE HDMI IN
HTIB HDMI IN >> CABLE BOX HDMI OUT
XBOX ONE HDMI OUT TO TV >> HDMI ARC IN or HDMI STB (let me know which one would be better please for this mix)
Everything is working fine amongst these devices but it seems however i throw the xbox 360 back into the mix i cant get sound. I tried just adding the xbox 360 to an HDMI on the tv and then adding an optical cable from the xbox to the HTIB and then selecting D. IN on the HTIB but still have no sound.... What am i missing here? Is my other setup wrong on the other devices if i want the 360 to work in the mix? PLEASE HELP !! Thanks
thuggy1111 is offline
post #2 of 19 Old 08-23-2014, 10:12 PM - Thread Starter
thuggy1111's Avatar
anyone that can help yet? Thanks !!
post #3 of 19 Old 08-24-2014, 08:07 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
Try changing the audio out on the xbox 360 to PCM or stereo. It appears the xbox 360 is ouputting audio the HTIB cannot decode.
HDMI Guy is offline
post #4 of 19 Old 08-24-2014, 09:48 PM - Thread Starter
thuggy1111's Avatar
Also whatever setup i have is now not giving me sound on my vuze app which streams video from my pc to tv. I have never had this issue in the past. Xbox 360 is now working btw. More detailed help is appreciated and in a post in the past this is how someone told me to hook up my devices but this was before the xbox one was in the mix. So any help is appreciated PLEASE!!! Also my tv and blu ray use a system called anynet+ for audio. I think the vuze issue is due to me having the optical connected to the xbox 360 into the blu ray. My reasoning is i think in the past when i would switch the source on my tv to the vuze streaming app, the blu ray would automatically switch the source from HDMI to D IN on the receiver however now it just stays on HDMI and if i switch to D IN manually it wont matter since the optical is connected to the 360!! This is confusing and frustrating since before i moved i had everything running fine. I knew i should have taken pictures before i unplugged everything lol
http://www.avsforum.com/forum/109-ho...ib.htmlhttp://
post #5 of 19 Old 08-25-2014, 07:19 AM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
You say the Xbox 360 is now working. How is it connected in the system? Knowing that may help me understand the pc issue.
Is everything except the pc working correctly now?
HDMI Guy is offline
post #6 of 19 Old 08-25-2014, 08:59 AM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1020
Anynet+ is Samsung's version of CEC (Consumer Electronic Control) which is part of the ARC/CEC protocols. It allows you to use a single HDMI cable to have bi-directional audio (ARC, receiver to tv and back again) and control your devices with a single remote (CEC). ARC/CEC is full of problems. The CEC protocols are not standardized and are optional. So not all mfrs use the same sets of protocols, even within the same mfr, to control your devices (turn on/off, automatically switch inputs, etc). They may work initially but if you add another device, update your system, etc, issues might happen. Also, all of your devices have to be ARC capable to use the ARC feature. The only real advantage of ARC is that it eliminates the need to use an optical cable. Both, ARC and optical, can only transmit 5.1 audio at best. I would disable ARC/CEC on all of your devices, use an optical cable, and get a programmable remote such as a Harmony to control all of your devices with a single remote.
Otto Pylot is online now
post #7 of 19 Old 08-25-2014, 04:05 PM - Thread Starter
thuggy1111's Avatar
Ok so i have the optical currently running from the xbox 360 to the surround system. Before i moved i had everything working so i have a feeling its just the way i am running the optical maybe? And yes everything is working now minus vuze on my tv. The way the optical is currently setup, maybe that has disabled the audio running on vuze from the pc to the tv? Any additional help is appreciated !!!
post #8 of 19 Old 08-25-2014, 04:09 PM - Thread Starter
thuggy1111's Avatar
Also, i have to switch to D. IN on the blu ray to get sound from the xbox 360. If i leave it on HDMI i get no sound which is expected since i have the 360 running on optical so thats fine. So i know i have one small configuration wrong currently. Also another poster said to disable all ARC on the tv, is that truly necessary? I heard that ARC can be handy in some situations such as apps on the tv etc like netflix. I dont think i need to disable it do I? Everything else is working fine and like i said before i moved everything was working fine but i foolishly didnt note how i was connected before i unhooked it all lol
post #9 of 19 Old 08-27-2014, 07:30 PM - Thread Starter
thuggy1111's Avatar
Antone else have any ideas how to solve the no sound from my vuze stream to tv? Thanks
post #10 of 19 Old 08-29-2014, 12:01 AM - Thread Starter
thuggy1111's Avatar
If anyone has a solution please help me out. I am willing to start from scratch if necessary to get the best audio video performance etc and get all devices working correctly again !!!
P.S. Vuze works find on my blu ray player via all share but still no audio when accessing vuze through the tv. Any help is greatly appreciated !!
post #11 of 19 Old 08-29-2014, 10:30 AM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
If I understand correctly you now have the Xbox 360 connected to the TV with HDMI. You also have an optical cable from the Xbox 360 to the HTIB.
If this is correct try running the current optical cable from the optical out on your TV to the HTIB. Leave everything else as it is now. I am assuming that the TV has a optical out.
HDMI Guy is offline
post #12 of 19 Old 08-29-2014, 07:09 PM - Thread Starter
thuggy1111's Avatar
ok i will give that a try and let you know how it turns out
post #13 of 19 Old 08-30-2014, 10:02 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi thuggy1111, this is my suggestion for connection with ARC enabled.
Cable box -> HDMI cable -> UN60F7100 HDMI-1
Cable box -> Optical cable -> HTF-5550 Digital Audio In
Xbox 360 -> HDMI cable -> Xbox One In
Xbox One Out -> HDMI cable -> HTF-5550 HDMI In
HTF-5550 Out -> HDMI cable -> UN60F7100 HDMI-2
Also ensure that surround sound is selected in Cable Box, Xbox 360 and Xbox One audio menu.
HDMI Guy and thuggy1111 like this.
JChin is online now
post #14 of 19 Old 08-30-2014, 11:40 PM - Thread Starter
thuggy1111's Avatar
ok great! Giving that a try now
post #15 of 19 Old 08-31-2014, 12:51 AM - Thread Starter
thuggy1111's Avatar
Thanks a lot JChin and HDMIGuy everything works great now!!!
post #16 of 19 Old 11-23-2014, 07:18 PM - Thread Starter
thuggy1111's Avatar
Update: ok with the current setup you guys suggested, everything is working but i do have one minor issue. The current setup has my xbox one and xbox 360 working on the same source. So for example when i click to go to hdmi2 and then switch to hdmi on HTIB i am on the xbox one. No biggie, i simply say xbox watch tv and then i am in the xbox 360. However i would rather have the xbox one working with my cable box so that i can simply switch between those instead. Is there a couple cords i can switch around so i have the xbox one and cable box working together instead of the xbox one and xbox 360 on the same source?
post #17 of 19 Old 11-23-2014, 08:12 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
I would try the following if the Xbox 360 has optical out.
Xbox 360 -> HDMI cable -> UN60F7100 HDMI-1
Xbox 360 -> Optical cable -> HTF-5550 Digital Audio In
Cable box -> HDMI cable -> Xbox One In
HDMI Guy is offline
post #18 of 19 Old 11-24-2014, 08:39 PM - Thread Starter
thuggy1111's Avatar
ok thanks i will give it a try. Also i like yo use my tv for netflix and vuze for streaming from my pc to tv etc. i should be ok and still have audio with this setup correct? i do have hdmi arc on this tv
post #19 of 19 Old 11-25-2014, 02:08 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 46
This should work fine. You will not be changing anything between the TV and your audio receiver. All my suggestion does is swap the cable box and the Xbox 360 connections.
HDMI Guy is offline
Reply Home Theater In A Box
