What should I do for a sound system? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JChin
Old 08-28-2014, 08:34 AM - Thread Starter
Liked: 0
Get home theater system with like 4-5 hdmi inputs, just buy hmdi switch with surround sound, or hdmi switch with sound bar.
Live in apartment. Couch wall to tv wall is like 11-12 ft. I'm like 8-9 ftish away from tv. Apartment living room is very wide, but tv seating part is like 12 ft wide.
Looking to spend $200-$400.
Wut do? Product Recommendations?
TheJasonSensation is offline
Old 08-28-2014, 10:38 AM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
There are some nice entry level systems made by Yamaha, Onkyo, and Denon that might suit your needs for apartment life. I would recommend a receiver/speakers only system and not one that is integrated. In other words, one that doesn't have a built-in blu-ray player.
Otto Pylot is online now
Old 08-28-2014, 11:46 AM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
+1
HDMI Guy is offline
Old 08-29-2014, 09:00 AM - Thread Starter
Liked: 0
http://www.newegg.com/Product/Produc...-008-_-Product
Das it mane?
Is it possible to play video games on it and music at the same time?
Old 08-29-2014, 09:59 AM
Otto Pylot's Avatar
Liked: 853
Two different sources at the same time? Probably not but I don't know for sure.
Old 08-29-2014, 12:51 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
With the Denon e300 you can do that.
http://www.accessories4less.com/make...airplay/1.html
A "Video Select" function, accessed via the OPTION button on the remote, allows you to listen to a USB/Tuner/Network audio source while watching a separate video source (including HDMI inputs!)
Then buy two speakers. You'll be much happier with a good receiver and two speakers than some limited flexibility home theater in the box or a sound bar.
http://www.ebay.com/itm/Polk-Audio-R...item540e8ae2f7
Add more speakers when you get more money or move to a new place.
Afro GT
afrogt is online now
Old 08-29-2014, 12:57 PM
afrogt's Avatar
Liked: 755
You could also buy two pairs of Pioneer bookshelf speakers for $87/pr so then you'd already have fronts and surrounds. Would just need a center.
http://www.amazon.com/Pioneer-SP-BS2...&keywords=bs22
Add the center for $67
Afro GT
Old 09-16-2014, 07:37 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Das it mane?
Hi TheJasonSensation, depend on your music source but its possible on the Onkyo HT-S3700 for tuner.
OnkyoUSA likes this.
JChin is offline
