HTiB give me some suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-19-2017, 09:38 PM - Thread Starter
sgtarky's Avatar
I want some good options. bluetooth reciever and bluetooth speakers >$600 and.........go!
sgtarky is offline
post #2 of 7 Old 01-20-2017, 12:50 PM
Otto Pylot's Avatar
Quoted: 1629 Post(s)
Liked: 1024
BT speakers? Google is your friend
Otto Pylot is online now
post #3 of 7 Old 01-20-2017, 11:47 PM - Thread Starter
sgtarky's Avatar
dude I know this...and looking at amazon. there are tons to choose from . I wanted recommendations from actual users.
sgtarky is offline
post #4 of 7 Old 01-21-2017, 09:31 AM
Otto Pylot's Avatar
Liked: 1024
Why don't you pick a couple of models that you think look good and post the links so we can check them out. Wireless has issues so you might want to consider a wired option if that's possible.
post #5 of 7 Old 01-29-2017, 07:48 PM
Liked: 0
NEW Home Theater Setup
Hi All,
I am fairly new to setting up a Home Theater and not an expert at Audio setups. I was searching reviews on BOSE, ONKYO, YAMAHA HITB's across various forums. Typically everyone mentions "BOSE" as a good marketing unit with average speakers. Didn't get much luck about ONKYO or Yamaha's as well. Majority of reviews talk about setting up a HITB with various components rather than taking a solution from 1 brand. I am trying to build my first HITB on a $500-$700 budget. Besides price, the other restriction I have is around Floor Speakers. I need something small for my Living room. The following is what I am looking to put together after doing research;
Receiver - Denon AVR-S510BT 5.2 Channel ($229)
Speakers - Polk Audio RM 705 5.1 Theater System ($140.26) {Was looking for Polk Audion RM6750 but can't find them online}
I am not based in the US hence have to purchase them from an online vendor like Amazon that will ship to an address that will eventually ship this out to me internationally.
I am happy to get suggestions on both Receiver and Speakers if any. As mentioned, I am not an Audiophile and will use the system mostly for Movies and Music. Besides small speakers, I would like to have the ability to stream music via Ios Devices (either via Bluetooth or WiFi).
Thanks for all your suggestions in advance.
Punkaj is offline
post #6 of 7 Old 01-29-2017, 08:17 PM
golfster's Avatar
Quoted: 560 Post(s)
Liked: 386
You want to spend more than $600, but what is your limit. I would suggest buying a separate receiver, speakers and sub. Sometimes you can get a decent receiver in an HTIB, but the speakers are usually the weak spot.
At the bottom end for reveivers
https://www.amazon.com/Yamaha-RX-V37...with+bluetooth
For a little more money, you get a lot more features
https://www.amazon.com/Yamaha-RX-V67...with+bluetooth
These review well and are inexpensive-not wireless
https://www.amazon.com/Pioneer-SP-BS...oneer+speakers
You can add the matching center
Dayton subs are good bang for the buck
http://www.parts-express.com/dayton-...oofer--300-628
On a tight budget, this is a consideration.
http://www.parts-express.com/51-home...oofer--300-694
For wireless, this will get you there with any speakers
https://www.amazon.com/Amphony-Ampli...ss+speaker+kit
https://www.amazon.com/Rocketfish-Un...ss+speaker+kit
golfster is offline
post #7 of 7 Old 02-16-2017, 09:16 AM
Travis R's Avatar
Quoted: 23 Post(s)
Originally Posted by Punkaj View Post
Hi All,
Im still running an onkyo 7.1 system i purchased in 05' and i love it. Im only upgrading the reciever as it has no hdmi switching. My theater is in my basement and the onkyo system will vibrate things off the kitchen counter upstairs if i crank it.
Travis R is offline
Reply Home Theater In A Box
