Yamaha DVX-C770BL vs. Onkyo HT-S790 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-15-2007, 02:00 PM - Thread Starter
Heartquake's Avatar
Hi everyone! This is my first post to AVS!
I am between these two HTIB. I know, they're not in the same league and HTS894 would be a better match to Yamaha but I can't afford more than 500 bucks.
Yamaha hooked me up so bad with its DVD-Audio/SACD, Divx & HDMI capabilities but SOUND is the most important issue for me.
Has anyone in here found a chance to listen both systems? What are the pros & cons about sound? (7.1 or 6.1 not an issue)
If you guys say go for Onkyo, I will continue to use my Toshiba SD4990 DVD/Divx player (altough I have some subtitle problems with it).
Perhaps you have a different suggestion (like Samsung HTQ70???)
As I told, sound is my first concern. I have to make a choice before Presidents' Day. I am damn confused.
Thanks from now.
Heartquake is offline
Reply Home Theater In A Box
