HTIB with wireless speakers? or is Rocketfish good? - AVS Forum | Home Theater Discussions And Reviews
Old 06-11-2007, 07:18 PM - Thread Starter
rratss's Avatar
I'm looking for an HTIB with wireless rear speakers and preferably wireless surround/side speakers as well. I would like to keep the bill under $500 but $600 will be fine as well. any recommendations?
edit: Would Rocketfish be a good solution? Either way, what is the best system that would fall into my budget?
thanks!
rratss is offline
Old 06-16-2007, 06:20 PM
Raymond Leggs's Avatar
Beware of Radio Interferance! I'd stick with wired HTIB's they sound Better.
Raymond Leggs is offline
Old 06-16-2007, 09:45 PM
nozerider's Avatar
The trade off in sound quality is most definitely not worth it. Added to the fact they're not actually wireless (need to run a power cord) it makes it a no brainer to stick with regular speakers.
nozerider is offline
