Official Samsung HT-AS720 thread w. updated first post. - Page 55 - AVS Forum | Home Theater Discussions And Reviews
post #1621 of 1650 Old 02-04-2010, 04:47 PM
bzzbee2's Avatar
Originally Posted by vicanwin View Post
I've owned the system since it first came out in the US, and about a month ago, the system started a popping noise in the front right channel. I've seen several others on the net with the same problem and it seem that as if it is a motherboard problem which will need to be professionally repaired, if it can be at all. As the unit is out of warranty, I think it might make more economic sense just to buy a new amp.
Here's my quesion: Can I replace just the head/receiver unit with another receiver? Will the subwoofer and speakers work with any middle price range receivers?
Mine started popping about 2 months ago... Now, no sound at all, except for 1/2 sound from the sub. This thing has been nothing but problems since I purchased it. I have probably got to watch the equivalent of 35 movies on it in the past year and a half, and now its dead and the warranty is gone.
Yippee!!
bzzbee2 is offline
post #1622 of 1650 Old 02-10-2010, 10:52 AM
dojugoo's Avatar
So, I have this system for quite a long time, and still very satisfied with it. Well, I was wondering if any of the handshaking problems have been fixed?
I own a Samsung Ln52A650, this HTIB, and a ps3. I read that plugging ps3 into the HDMI satellite port gets rid of the handshake issue? Anybody confirm this?
Also, what is the best way of minimizing input lag? Is connecting HDMI out from receiver to HDMI2 in the TV and renaming to PC the best option? Does the ps3 going through the receiver to the TV cause any lag?
Thank you for answering all my questions
dojugoo is offline
post #1623 of 1650 Old 03-04-2010, 10:59 AM
urir10's Avatar
Hi All
I just joined the site and this is my first post, sorry to bring it up again.
I currently have the HT-AS720 with a cable box and a ps3 connected to it via HDMI, and HDMI to TV. The problem im having has been there for awhile but i just tried to ignore it but now its just really annoying, and i couldnt find help anywhere not even Samsung.
Anyways, when i watch tv i get perfect sound and picture, with the ps3 thou while playing certain games like Battlefield Bad Company 2 i will get like a glitch in the sound from the as720. What i mean is, the lcd on the AVR shows the input mode and all the speakers connected than from time to time(and its random) the sound will disapeare for split second and everything on the AVR display will disappear except the input mode (So basically the speakers pictures). This is really annoying when the sound starts disappearing like every other minute. I searched everywhere and didnt find a solution. This is what i already tried:
- Connect ps3 directly to TV (works fine, no glitches)
- switch HDMI cables , switch INPUTS - didnt help
- Use an optical cable from the ps3 to the AVR - same problem
Since its so random, could it be that maybe the output volume is to high that the speakers cant handle it?
P.S - I had the same issue with the Cable box but it works fine now somehow
urir10 is offline
post #1624 of 1650 Old 03-21-2010, 12:19 PM
Spanbauer's Avatar
Originally Posted by Bad_Boy_ View Post
I searched the thread, but I only found similar situations, and they didnt help me. So I have a problem...
I have my PS3 plugged in DVD (hdmi 1), and Direct TV HD box in SAT (hdmi 2).
I only get audio with my DirecTv box. The ps3 through dvd/hdmi has no audio at all.
If I switch the PS3 to SAT and DirecTv box to DVD, audio on ps3 works and not the box.
I've set the DVD audio to hdmi and still no dice to whatever is plugged in the DVD hdmi slot. Any suggestions?
edit: if it helps, video works fine for both.
If nothing works, I'll probably just get an optical cable for the Directv box, and put ps3 back on SAT... which I assume should work.
I started having a similar issue a few weeks ago; suddenly, the DVD HDMI port would carry only video and not sound, while the SAT HDMI port worked fine. I swapped my xBox 360 and blu-ray player to opposite ports, pulled the power on everything for ten seconds, and when I plugged it back in everything worked again. This past Friday, same issue with the blu-ray player again (now on the SAT HDMI port), and once again pulling the power to everything seemed to resolve it. Then today, it was the xBox 360 that only had video. Again, pulling the power to everything (doing just the receiver didn't work) was the only thing that got it working again.
The problem is obviously becoming more frequent, and it's a real annoyance. What should I do? What can I do? I don't have an extended warranty of any kind.
Click here for my home theater setup
Spanbauer is offline
post #1625 of 1650 Old 03-25-2010, 12:50 PM
Spanbauer's Avatar
Anybody have suggestions? I've been trouble-free for a couple days now, but I don't expect that to last. Thanks.
post #1626 of 1650 Old 03-25-2010, 12:54 PM
tamahome02000's Avatar
I'm curious. Has anyone ever tried the HDCP Compliance Test on this device, maybe with the Cyberlink program on an htpc? I think this device was made before the test was out.
tamahome02000 is offline
post #1627 of 1650 Old 04-09-2010, 09:44 AM
savior02's Avatar
why everytime i turn on my tv and amp the receiver after 3 seconds changes from the last source on to tv optical 3?? why!?? anyone else have this problem? my tv is using hdmi! not optical!
savior02 is offline
post #1628 of 1650 Old 04-09-2010, 10:14 AM
Mine does that too. But I take that as a good sign, that hdmi-cec is working. I can use the tv remote to control the volume of the avr. :/
post #1629 of 1650 Old 05-23-2010, 06:02 PM
mr dinosaur's Avatar
im hoping someone could really help me out with this. one day all of a sudden i started getting alot of static from my front right speaker. i checked the wiring, everything looked ok. undid wiring on left speaker and moved the right one over, no static. went behind the reciever and every speaker i connect to the speaker knobs all the way on the left i get static. i figure something is wrong with the knob, might need cleaning or something so i open the reciever and spray some contact cleaner. same static. anything else i could try? the reciever is no longer under warranty and i have no issue with it and dont want to upgrade/get another.
thanks
mr dinosaur is offline
post #1630 of 1650 Old 05-23-2010, 06:55 PM
well i see now thru browsing this thread its a common problem. is there a fix for it or how much would it be to fix?
thanks
post #1631 of 1650 Old 06-12-2010, 05:26 PM
FirestarterIT's Avatar
thanks
Hi, new to forum, and this is my first post. Sorry if it's a bit long!...
Yeah, I started having the same problem about a month ago. The static started getting progressively louder, and then the other speakers would have no audio at all. I tried doing the same steps as well, and connected brand new Monster speaker cables, but no luck.
I ended up having to disconnect the front right speaker wires just to get sound out of the rest of the speakers. But now when watching anything, the sound is barely audible, even up to the 'Max' volume, and sometimes spikes to extremely loud levels for a short time. Of course, it's most likely past warranty by now (bought from Circuit City during the mass closings). So I'm kind of hesitant to contact Samsung, since from what it sounds like on here and elsewhere that they're not too helpful, even though this definitely is a manufacturing issue affecting many customers.
I'll probably have to switch it out with the Harman Kardon AVR-146 I have for the time being. I certainly do not want to spend another $160 or so to send it out for service for who knows how long. But now I have a brick of an AVR that I don't know what to do with. All I can say is, I've severely lost faith in Samsung products... Hopefully, some kind soul can help us frustrated folk out!
FirestarterIT is offline
post #1632 of 1650 Old 06-20-2010, 08:30 AM
Well, I finally decided to give Samsung a call, and boy what a mistake that was. I spent at least half an hour on hold, just to be told that "sorry, we can't accommodate you. Goodbye." Wow, real quality customer service there. They were going to charge me $80 to send it in for service for a defective product line. What a joke. I'm seriously never buying Samsung ever again. I suggest everyone here to do the same...
post #1633 of 1650 Old 08-24-2010, 09:46 AM
MoNkLorD's Avatar
I was going to ask if anyone has ever had to get their receiver repaired outside of warranty, and if so where did you take it to and about how much just to get it looked at? mine finally went down, I already picked up a replacement but would hate to see this just go to waste, i enjoyed it for the short life i got out of it.
thanks,
MoNkLorD is offline
post #1634 of 1650 Old 11-09-2010, 04:46 PM
cgking114's Avatar
Hello! I was wondering if anyone had a remote code for a Directv Remote control. I can find no code that will work. Thanks.
cgking114 is offline
post #1635 of 1650 Old 01-09-2011, 10:30 AM
JimmyHaver's Avatar
I bought the AS720 in Dec 2007 and now suffer the same issue. Increasing static from the right front speaker until the system is unusable. I also won't be buying any Samsung products in the future.
Does anyone have a good suggestion for a replacement receiver for this model?
thx
JimmyHaver is offline
post #1636 of 1650 Old 02-04-2011, 04:59 PM
66gto's Avatar
add me to the long list of broken AS720s. Mine lasted almost 3 years (which apparently is better than most), but the dreaded static, which started just on the one side, has now spread to the center speaker too, so it's unusable (and Samsung support was useless). Looking for any suggestions on a fix (if there is one), or ideally a replacement receiver (ideally NOT Samsung again).
66gto is offline
post #1637 of 1650 Old 02-20-2011, 10:32 AM
Penetronn's Avatar
Except for the speaker settings bug (which really isn't a big deal as long as you don't find the 10 foot distance) I've been very pleased with this unit. No static yet. Anynet+ works well too.
Samsung LN46C630K1F
Samsung HW-C700
Xbox One
Xbox 360 E
Xbox Live: Penetronn
Penetronn is offline
post #1638 of 1650 Old 02-20-2011, 11:52 AM
66gto's Avatar
I was happy with the unit too, until the problems started less than 2 years after purchase, and having Samsung turn their backs on their customers. A couple minutes with google shows the static problem to be common and widespread with this unit, and customer support similarly useless for others having the same issue. That's enough for me to never buy Samsung again.
I replaced it with a Pioneer VSX-520K on sale last week for less than the price I was quoted to fix the Samsung unit, including an extended warranty fee. Hopefully I won't need it.
66gto is offline
post #1639 of 1650 Old 06-10-2011, 06:09 PM
Sigifrith's Avatar
Sorry for bringing this back from the dead.
Would someone like to sell me 2 speakers, so I can get the full benefit of this system?
Sigifrith is offline
post #1640 of 1650 Old 09-25-2011, 12:44 PM
Deaks2's Avatar
Does anyone know if this unit supports HDMI 3D pass through?
Edit: Never mind, as per http://www.samsung.com/us/support/ow...oduct/HT-AS720 it doesn't.
Deaks2 is offline
post #1641 of 1650 Old 10-01-2011, 04:30 PM
KatesDad's Avatar
I have a full Samsung system (TV, Blu Ray, 720) and everything is connected via HDMI.
I hit the info button on my TV tonight and it showed the video at 720p. So, in my amazement (I have owned this now for 4 years), I call Samsung and they say it only supports 720p passthrough.
But, when I am on this thread, it says it supports 1080p passthrough, yet, I cant find or see (after a few hours of searching this thread) what I can do to change my settings on the receiver to get 1080p, if it exists.
Anyway, thanks for the help. A 53-page post is hard to follow and get the info I am looking for... Thanks!
KatesDad is offline
post #1642 of 1650 Old 10-02-2011, 09:32 AM
mccorry's Avatar
I've got the static issue (right front speaker) now, as well. Started about a month ago and is getting worse with time.
Anyone have a suggestion for a replacement AV Receiver that will work with our HTIB speakers? I like the speakers... I just want to get rid of the 720 junk receiver.
mccorry is offline
post #1643 of 1650 Old 02-07-2012, 02:20 PM
redzone's Avatar
Has anyone taken apart the subwoofer?
I want to find out if its worth trying to build a new enclosure for it or reusing the amp on a new sub/box. problem is im currently using it in my setup and cant risk damaging it
redzone is offline
post #1644 of 1650 Old 04-20-2012, 07:00 PM
AzDragonLord's Avatar
Quoted: 51 Post(s)
I'm in the same position...it's so bad we cannot use it any longer. Which receivers will work with our current speakers?
Media Computer Specs
ASUS H87M-E LGA 1150....Intel Core i7-4770 Haswell....Intel Network Adapter....8GB DDR3 SDRAM....Windows 7 x64.....Plex....Drobo 5N....Drobo Gen2
AzDragonLord is offline
post #1645 of 1650 Old 04-20-2012, 09:06 PM
Otto Pylot's Avatar
Quoted: 1667 Post(s)
Liked: 1042
Not that it helps you folks any but the first lesson of buying a HTiB system is to look at the speaker connections and plan ahead. That being said, can you modify the connections for a "universal" fit, ie bare wire or what ever.
Otto Pylot is online now
post #1646 of 1650 Old 04-06-2013, 11:10 PM
toysareforboys's Avatar
Mine has the exact same problem. About a month ago the front right speaker started to pop/crackle so I just unplugged it, then a few days ago I get almost no sound from any of the speakers except the subwoofer frown.gif
Is it worth getting it repaired? Cheapest amp I can get around here that'll work with the 4ohm speakers is like $400 frown.gif Yamaha RXV473 B
-Jamie M.
toysareforboys is offline
post #1647 of 1650 Old 08-15-2013, 06:17 AM
Shawzborne's Avatar
Hi Guys,
ever since I have owned my reciever I could not get the HDMI audio to go through my TV ps3 and reciever, just says
"This HDMI device cannot be used for audio output"
I have a feeling its my tv not allowing it through the model of my tv
Toshiba Cinema series
52XV545
any help would be great thanks
Shawn
Shawzborne is offline
post #1648 of 1650 Old 07-07-2014, 05:58 PM
markp2's Avatar
Anyone still own one of these? The other night I left to go to a baseball game and left the radio on low for the dog. About two hours later my apt mgr started calling me to say that the music was way to loud and I need to turn it down. Much to my surprise, when I got home the volume had been turned up EXTREMELY loud! Remote control was on top of the cable box.. nobody else home, dog was in crate. Is there gremlins in this ****in thing? Anybody got any similar happenings? I thought maybe a power outage could do it and I can't confirm if that happened while I was gone..
markp2 is offline
post #1649 of 1650 Old 07-07-2014, 06:09 PM
I can't believe yours still works!!
Never had any issues like that, and I had it playing for 14 hours a day sometimes, but never on REALLY low volume.
-Jamie M.
post #1650 of 1650 Old 08-22-2014, 10:02 AM
Penetronn's Avatar
Mine still works too. Thinking about replacing it soon though since Samsung has apparently dropped their support of HDMI-CEC.
Reply Home Theater In A Box
