DIY Screen Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-12-2008, 02:44 PM - Thread Starter
MPF777's Avatar
Hello,
I just got my dad a BenQ MP512 ST for his basement. I want to make him a low end home theatre and my next step is making a screen...
It's a short throw and the image size is apparently 27.5 to 300 depending on distance. I would never have it more than 4-6 feet from the wall and was wondering how big I should build the screen? The wall I am working with is about 8 feet wide... I'm new to this and don't want to start building the screen without some opinions from you guys regarding the size...
MPF777 is offline
post #2 of 4 Old 12-12-2008, 05:49 PM
20fan's Avatar
Originally Posted by MPF777 View Post
Hello,
How about throwing an image on the wall from where you would have the projector mounted. That way you can get a feel for what size would go well in your intended theater area. As for building a screen and frame, check out my frame build in my signature. It will give you at least 1 idea on a frame option.
20Fan
Ohio State Buckeyes- GO BUCKS !
My Aluminum frame build
20fan is offline
post #3 of 4 Old 12-12-2008, 07:37 PM
tiddler's Avatar
What condition is the wall in?
The cheapest solution would be a painted screen. That requires the wall be clear of all obsticles such as outlets and vents. Even if your long term plan is to build a screen the wall can serve as a very good interim screen.
tiddler is offline
post #4 of 4 Old 12-12-2008, 10:32 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1774 Post(s)
Liked: 808
Hello,
It's a short throw and the image size is apparently 27.5” to 300” depending on distance. I would never have it more than 4-6 feet from the wall and was wondering how big I should build the screen?
At 6' your screen size would be 60" x 80" (100" diagonal ) The 512 ST has no Zoom so if you place it closer, your image will be reduced accordingly. But as you know, it's a very bright PJ. Most likely you will run it on "Economy" (...if it possesses that option ) You should consider a medium Flat Gray Mix applied directly on the wall if you can prep the surface to a slippery smooth state. Look to this link/thread and consider using such a simple Gray mix w/Poly.
http://www.avsforum.com/avs-vb/showthread.php?t=1092267
It sounds like your placing the Pj on a table....yes? If not, be advised that the 512 has considerable Image Offset, and so will have to be mounted close to the ceiling.
MississippiMan is offline
Reply DIY Screen Section
