DIY masking ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-23-2009, 03:06 PM - Thread Starter
68sting's Avatar
What forum or site would I find some good diy masking ideas for a 16:9 screen?
thanks
Lance
68sting is offline
post #2 of 10 Old 03-25-2009, 10:16 PM
christer W.'s Avatar
This is a clean solution:
http://www.avsforum.com/avs-vb/showthread.php?t=1090889
Good luck
Chris Whitworth
christer W. is offline
post #3 of 10 Old 03-30-2009, 12:56 AM
docprego's Avatar
I've made DIY masks for 2 different screens, a DIY 89" and an Elite 120". Both screens were 16:9 and I masked them to 2.40:1 using pretty much the same method on both.
For the DIY 89":
http://www.avsforum.com/avs-vb/showt...0#post13396880
For the Elite 120"
http://www.avsforum.com/avs-vb/showt...323&highlight=
My Ridiculously Inexpensive Dedicated Kick *** Home Theaters!
RIDKAHT <The Original>
RIDKAHT <<The Sequel>>
RIDKAHT <<<Part III>>>
docprego is offline
post #4 of 10 Old 03-30-2009, 04:35 AM
miketyler's Avatar
Has anyone sucessfully masked a retractable screen?
miketyler is offline
post #5 of 10 Old 04-02-2009, 08:45 AM - Thread Starter
68sting's Avatar
Thanks for the ideas. I'm going to use the foam board. Can some one tell me what size the bars are on a 110" 16:9 screen when viewing 2:35.1.
Lance
68sting is offline
post #6 of 10 Old 04-02-2009, 08:52 AM
CMRA's Avatar
Quoted: 18 Post(s)
Liked: 26
thanks
Lance
Someone is starting out right. Masking, not borders. Now that's a smart solution.
CMRA is offline
post #7 of 10 Old 04-02-2009, 08:54 AM
scottyb's Avatar
Quoted: 18 Post(s)
110 = 54 X 96.....1.78
41 X 96.....2:35 (actually this would be 96.35" wide)
so the difference is 13" divided by 2 equals 6.5" for each mask.
Depending on how particular you are it could be off by a quater inch.
If you want exact put a pic up and measure on your screen but for most my calculations should be good.
Scott
scottyb is offline
post #8 of 10 Old 04-02-2009, 08:56 AM
rboster's Avatar
Quoted: 886 Post(s)
Liked: 742
Lance
Your best bet is to put an image on the screen and take actual mesurements.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
post #9 of 10 Old 04-02-2009, 09:02 AM
CMRA's Avatar
Quoted: 18 Post(s)
Liked: 26
OP, follow this link to an excellent solution.
http://www.avsforum.com/avs-vb/showt...2#post15034952
CMRA is offline
post #10 of 10 Old 04-02-2009, 08:04 PM
docprego's Avatar
Put up an image of a film in the ratios you want to mask. I was lazy on my measurements on my latest masks and after covering them with velvet found that I was entirely unhappy with their size. The image would overlap the mask by 3/4 an inch at the top and bottom. It was really annoying so I painstakingly centered my pj to the screen, projected a 2.35:1 and a 2.40:1 movie on the screen and measured the bars. On my 120" screen I got 7.5 inches for each bar, the first set I cut to 8.25 inches. I am now very happy with the masks because on both the ratios I listed above there are no grey bars and no light over spray.
docprego is offline
Reply DIY Screen Section
