RS-MaxxMudd Mix (the official) - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 154 Old 03-26-2011, 07:49 AM - Thread Starter
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
hmmm. that's interesting?! i thought that i had.
done.
pb_maxxx is offline
post #152 of 154 Old 12-02-2012, 05:56 PM
tecnogadget's Avatar
Hi!! I want to install a screen on my home theater. It's going to be a 102" size. Im thinking about using 1cm MDF as substrate , because i want it to be totally flat and smooth surface.
Proyector : Epson Home Cinema 8100
Which should i choose?
RS-MaxxMudd HGC v.2
(for high gain contrast bat caves ht's)
20 oz. Delta Pearl Metallic #02601
12 oz. Liquitex Basics Silver
9 oz. Behr UPW flat
12 oz. Minwax Polycrylic - Satin finish
15 oz. distilled/tap water**
RS-MaxxMudd LL v.2(for lower lumen pj's and controlled light home theaters)
8 oz. Liquitex Basics Silver
12 oz. UPW flat
I consider my PJ a Low Lumens one , because in ECO mode ist just 450 lumens.
"At the Core , its all about the music" S. Jobs
tecnogadget is offline
post #153 of 154 Old 12-03-2012, 03:25 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1773 Post(s)
Liked: 808
That MDF will be "very" heavy, and should be sealed on both sides with at least two coats of Primer
6mm Sintra is a far better choice.
Go with RS-MaxxMudd LL
tecnogadget likes this.
MississippiMan is offline
post #154 of 154 Old 12-03-2012, 12:30 PM
I know MDF will weight a lot but the idea was to attach it to the wall and i figure it out.
My problem with Sintra is that where i live is not that easy to get. I'll look around to check if i can get it.
Remember , my priorities are Flatness and Smoothness . Sintra is perfectly smooth i know , but with just 6mm thick , would that be totally flat without banding? If i choose 6mm Sintra , should i build a frame first?
Reply DIY Screen Section
