Painted screen for Sanyo PLV-Z3000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-09-2009, 11:32 AM - Thread Starter
loafyloaf's Avatar
I am painting a screen in my newly finished basement, I need help.
My PJ is a Sanyo PLV-Z3000
Specs:
Resolution HD (1920 x 1080)
Brightness 1200 lumens
Contrast Ratio 65000:1
Uniformity 85%
No. of Colors Full color
Aspect Ratio(s) 16:9
Screen size: 102-110"
Seating is 15' away, pj is ceiling mounted at about 16.5'
The space is not a dedicated theater room, although ambient light is 95% controllable. I would also the to be able to have some lights on for parties, gaming & the big game (although in Cincinnati, that may never come... LOL)
I would like to keep the formula as simple (and inexpensive) as possible, as I usually have to do DIY projects twice. I have Lowe's, Home Depot and Michaels all available locally.
I will be spraying the paint over light brown (which was also sprayed, ie very smooth)... primer? Also, what influences viewing angle? FYI, I will be trimming the screen in 3" Screen Flok.
Thanks in advance for your time, you guys have really invested yourselves in this board!! THANK YOU!!
loafyloaf is offline
post #2 of 3 Old 06-09-2009, 12:52 PM - Thread Starter
loafyloaf's Avatar
Originally Posted by kbgl View Post
I'd say use an N7 to N8 gray with 20% to 30% poly mixed in.
I'm a newb, so N7 to N8 gray (Behr SS?)... what does the poly do? What about some pearl-somethingorother?
post #3 of 3 Old 06-13-2009, 02:51 PM - Thread Starter
loafyloaf's Avatar
Curious why no one is answering...
Reply DIY Screen Section
