Simple Bonus Room Theater w/110" Gatorboard Foam SF Screen - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 11-03-2009, 07:10 PM
wkornf's Avatar
Nice setup for sure!
Quick question tho, how is it that you have transformers and iron man at 16:9?
Do you have some kind of cropping going on.
Wayne
wkornf is offline
post #32 of 38 Old 11-04-2009, 12:13 AM - Thread Starter
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2161 Post(s)
Liked: 975
Wayne
The Panny was in "Zoom" mode so a percentage of the image was/is indeed cropped.
In the "TV" shots it was back in 16:9 mode.
MississippiMan is offline
post #33 of 38 Old 12-30-2009, 03:16 PM
bucknell's Avatar
MM,
I'm very interested in the gator board product.
About a year ago, I was going to mud and smooth out a 5x12 screen the old fashion way.
Looks like procrastinating may have paid off
Just curious though, you get better performance from the gator board then a Wilson Art laminate if one were to apply Silver Fire for example?
I ask because there are advantages for me to get a roll of material into my basement as opposed to managing a 5x10 square piece around a corner.
If the gator board is flexible enough perhaps there's no issues.
bucknell is offline
post #34 of 38 Old 12-30-2009, 03:40 PM
Laserfan's Avatar
Quoted: 21 Post(s)
Liked: 34
Originally Posted by bucknell View Post
...there are advantages for me to get a roll of material into my basement as opposed to managing a 5x10 square piece around a corner. If the gator board is flexible enough perhaps there's no issues.
MM will reply--but fyi my 1/2" GF board has no flex whatsoever, zero! I imagine there might be some flex in a much thinner board, but I sure would not count on it (depending on the corner you have to navigate). And a thinner board means more potential for damage just getting it home...
Laserfan is offline
post #35 of 38 Old 12-30-2009, 04:23 PM
bucknell's Avatar
I can get 3/16" GF and can probably find someway of having Regal sandwich it between card board pieces for the ride home.
But it if has no flex than it's a no go.
Also, I haven't checked the Wilson prices lately but given the price quote I got today from Regal, it should be comparable.
Thus, if MM says performance is equal between the 2 with an applied spray technique, I think I know what I need to do.
bucknell is offline
post #36 of 38 Old 12-30-2009, 10:38 PM - Thread Starter
Liked: 975
That thickness Gatorboard will have plenty of Flexibility.
Well check for sure because WA-DW should be significantly more expensive
Well MM sez:
WA-DW has more a bit more gain than GB, but it comes with enough extra "frame-related" mounting issues to negate any advantage that offers. Add to that the hike in price and that makes GF/GB my advised selection.
BTW, I and one other person carried the 96" x 54" sheet you see in this thread around a upward 90 degree corner in a stair well. Yes, it was sent up at a steep angle, but it easily bent around the corner, and it was no real effort to keep the inside surface from out of contact with the inside edges of the corner as well..
You'll have to bugger it up pretty badly (...as in gouge or peel....) to not make any coating cover up a 'rub-like' blemish.
post #37 of 38 Old 05-04-2010, 05:35 PM - Thread Starter
Liked: 975
Old Thread Warning
This Thread is more than 125 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
125 days? Old? Serves no purpose?
I beg to differ.
post #38 of 38 Old 05-16-2010, 06:01 PM
billybobg's Avatar
Quoted: 42 Post(s)
Liked: 46
While it is a thread on spraying Gator Foam, the general info on this thread makes me feel that it should be a sticky thread. Just my $.02
bob
Home Theater Man Cave: Onkyo 7.1 Klipsch LaScala Mains, Shortened LaScala Klone Center, Klipsch Academy Surrounds and Rears; Panasonic AE8000, Panasonic BDP 460, 117" DIY Screen.
Garage Man Cave: LaScala Industrial Splits; Second hand Denon Amp
billybobg is offline
Reply DIY Screen Section
