Painters drop cloth for screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-27-2009, 12:48 PM - Thread Starter
UnknownShadow's Avatar
Still searching for a local source on some type of material to use for a 106" screen. Has anyone tried using a painters drop cloth? I found two different 9'x12' ones that may work. One is plain white and fairly thin. Though it is certainly tough enough to stretch over a frame. The other is a heavy duty "canvas" type of cloth. It is a dark color so will need to be painted. Hmmmm decisions decisions!
Anyone else ever try some kind of painters drop cloth for a screen?
UnknownShadow is offline
post #2 of 5 Old 10-27-2009, 02:03 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I used one initially as a temp screen to test out my projector and screen size. I wouldn't want it as an actual screen though.
You can use a bed sheet for that matter but I would look into Dazian black out cloth or look at the spandex options which have arisen recently DIY section for local fabric stores.
oman321 is offline
post #3 of 5 Old 10-27-2009, 02:09 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
oman321 is offline
post #4 of 5 Old 12-06-2012, 12:11 AM
Envikx's Avatar
I have a Painter's Canvas drop cloth I hang on my wall. From things I have read online, it seems fine to paint and use screen paint. It does make a difference! Its very cheap (bought mine for about $11 (6'x9'). I also plan on making a screen out of it (fixed frame). Let me know what you end up doing!
Envikx is offline
post #5 of 5 Old 12-06-2012, 04:14 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
I have used drop cloth canvas for many test screens. In my signature there are some links that show the test screens. It is the poorest quality canvas you will find. And depending on the size it will have seams and the surface will have some knots and such. You can buy some really good quality canvas that is perfect for not much more money and it will come rolled and up to 12 feet wide.
Bud
bud16415 is offline
Reply DIY Screen Section
