I went to doable and...i am confused - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-01-2010, 03:56 AM - Thread Starter
littlehuman's Avatar
hello everyone,
i went to doable diy screen a year ago. I just moved to a new apartment and it has white wall. Before I hang my screen, i tested my projector directly to the wall and...i could not find any difference between the wall and my doable screen. I hung my doable and tried to see difference between the wall and doable. I can't find any differencele between doable screen and the wall.
I am thinking to project directly to the wall. What do you guys think?
littlehuman is offline
post #2 of 2 Old 01-01-2010, 07:02 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2053 Post(s)
Liked: 909
Originally Posted by littlehuman View Post
hello everyone,
i went to doable diy screen a year ago. I just moved to a new apartment and it has white wall. Before I hang my screen, i tested my projector directly to the wall and...i could not find any difference between the wall and my doable screen. I hung my doable and tried to see difference between the wall and doable. I can't find any difference between doable screen and the wall.
I think your very lucky to have a smooth white surface to project as large an image upon as you want. Doable or any other "materials" that are considered "Hang & Shoot" are desirable because of their being exactly that.
Someone at sometime had to effectively finish out your Drywall and apply primer and paint in a expert manner to provide you with the surface your using. Otherwise you'd have had to do it yourself (DIY ) or opt for something like Doable if such was an impossible or distasteful task.
perhaps the best that can be offered is this;
littlehuman's post shows that you can paint just as good as a surface as can be manufactured....leastwise when it involves a simple color on top of a well finished out surface or material.
MississippiMan is online now
Reply DIY Screen Section
