How Many Lux in an 100" Screen With a 1.0 Gain ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-17-2010, 06:57 PM - Thread Starter
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
Hey there
I'm buying some Retro Reflective Fabric and specs come in Lux /candle power plus the Lux comes in ranges from 65-600
So I'm trying to figure out how many Lux ( candle power ) would be in a 100" screen with a Gain of 1.0 so I can get an idea of what percentage of LUX the fabric should have.
The power of a car engine is measured by horsepower - the more the better. The same can be said for reflective material, which is measured by candle power (cd/lux/m²). There is a clear relationship between retroreflective performance of a surface and the distance at which it can be seen. According to 3M data, the retroreflective performance level (candle power) of white clothing is 0.1 - 0.3 , a license plate's performance level is at 50 and typical retroreflective silver fabric has a performance level of 500.
As the following chart depicts, with increasing retroreflective performance, sight distance also increases, clearly demonstrating that reflective materials allow for optimal visibility during low light level conditions. However, not all reflective materials are the same, as there are reflective materials available that range from 65-600 candle power. Remember, the brighter the better.
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
Reply DIY Screen Section
