Is it possible to DYI a Double-sided/Dual Image Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-08-2010, 02:01 PM - Thread Starter
thachertom's Avatar
Does anyone have any ideas how I could DYI a projection screen that allows the image to simultaneously be viewed from either side of the screen? This is not for a home theater but rather for use at a family reunion where I want to project photos and have them be viewable from both sides of a banquet room from a central point, rather than only projecting against one wall on the far side of the large room. I know that such screens exist and can be purchased but as this is really for a one-time use, I need a less expensive alternative.
thachertom is offline
post #2 of 4 Old 03-08-2010, 05:00 PM
krauos's Avatar
Any translucent fabric will work, the image wont be as bright as black out cloth since some light will be going through. You will also have to worry about people being able to see into the projector lense from the 2nd side (if they are close to to the centerline axis). Also note the second side image will be mirrored. Dazian fabrics had a sheer / translucent type fabric that should work.
krauos is offline
post #3 of 4 Old 03-09-2010, 04:20 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2179 Post(s)
Liked: 981
material designed for that sort of thing exist via a company that specializes in Stage and Business displays. It's not cheap. Other "DIY" things work "pretty good" but almost all those "others" have significant loss of brightness on one side, and most all of those have a degraded image on the "projected side".
It's "not" having that degradation that make the Mfg. material cost a bundle.
Stretched Spandex is most likely your best, "least expensive" option followed by a specialty Rear Projection Back Drop material from Diazan
MississippiMan is offline
post #4 of 4 Old 03-09-2010, 10:05 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Welcome to AVS.
Here is a thread related to spandex screens http://www.avsforum.com/avs-vb/showthread.php?t=1228287
Can tell you first hand experience that works great, specially for a one time use. However, ambient light, like with any projector, is a factor on the side that the image is being projected onto. If you use the screen for a rear projection, if you limit or have no light on the rear side, you could have ambient light on the front side and the image would still be acceptable, this is one of the advantages of rear projection.
Now if you want to see the image on both sides ambient light comes into play plus the consideration mentioned above.
If you consider a spandex screen, the more cotton the fabric has the better, also there are 4 way stretch and 2 way stretch fabrics.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
Reply DIY Screen Section
