Designer White laminate vs. Matte White material - AVS Forum
post #1 of 1 Old 03-22-2010, 12:46 PM - Thread Starter
Jim McC's Avatar
Liked: 32
I'm trying to decide between these 2 options: Which would give the better image? Totally light controlled cave.
1) Designer White laminate
2) White matte material from a cheap pulldown screen. I would cut material
off and staple to a DIY frame I have. Choices are "Accuscreens" matte
white, Elite Max White, 1.1 gain. There may be a couple more also.
Would these screen materials be easy to get tight enough on frame to staple on back? Thanks.
Jim McC is offline
Reply DIY Screen Section
User Tag List
