Acer H5360 Placement/Image size... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-01-2010, 01:48 PM - Thread Starter
joemcgloo's Avatar
Hi, so, i'm new to this forum, so i'm not sure if this is the right section, but ...
I just built a screen for my soon to arrive Acer H5360. It measures 123" wide x 60 in high. Currently I have it dropping ~1' from the ceiling (well, crossbeams), which is in a basement, so I actually have room to go past the cross beams and up higher ... Now I have ream elsewhere on this forum about drop height of the projector, but still, things are unclear for me ... the image offset is supposedly 13.2%... so if I were to install it (upside down) via a ceiling mount, what should the height of the projector be relative to the screen/cross beams? By the way, the throw distance I am aiming for is ~16' to 17', resulting in around a 130" to 145" diagonal (probably ~140"). Any other advice would be appreciated ... I also attached a rough CAD sketch I made of the area. (the dotted red bars in it are obstructions or beams, ignore them...)
joemcgloo is offline
Reply DIY Screen Section
