New 2.35:1 Silver Fire screen project. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 95 Old 01-15-2011, 10:07 PM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
I will be replacing my current 85" 16:9 screen with a 2.35:1 Silver Fire LF screen. Right now I am still gathering the materials and tools for the build, and I still have a some questions as well.
I have (or have ordered) all the paint components, and have a mirror on the way. Still haven't decided what I am going to use as a substrate for the mirror. MDF would be simplest, but I don't know if I want to deal with that much weight. Considering a frame with hardboard or something similar. Is there some reason not to use something called 5.2 Lauan underlayment instead? It looked like 3/16" plywood, and seemed like it had more rigidity than hardboard.
I don't have a sprayer, and wonder if the Wagner Control Spray Plus is still the ideal tool for the job, or has someone (MM perhaps?) tried the bargain refurbished sprayer that MississippiMan has pointed out at Gleempaint with equal success?
If the Wagner is still the best I have no qualms about spending the extra money for it, but if the refurbished gun is as good or better for this job, then less $ is more.
NewGate88 is offline
post #2 of 95 Old 01-15-2011, 10:56 PM
Point Source
beastaudio's Avatar
Quoted: 3999 Post(s)
Liked: 3308
First off, welcome Mr Gate!!!! Glad you are going the DIY route, and you are in the right place to find the good info. While I am relatively new at the game here, I will give you as much Info as I know.
technically speaking, the mirror is going to be your substrate, so whatever you put behind it is your choice. I dont want to overstep my boundaries here as there are others here including MM that know much more than I do, but if you are just looking for some thing to go behind the mirror, either go with something as lightweight and rigid as possible (for a movable screen) or just put the mirror straight on the wall!!!! I would consider 1/4" MDF for a more ridgid surface to put the mirror on. the MDF will tack well with whatever you use to glue the mirror on and it will be one of the smoother options out there. if you want lighter weight, Im sure there are some 1/8" backings.
A more important question is what are your plans for screen size? Are you sticking with the current 85"? with the 2.35, while you are at it, may be a fun/good idea to see what you can do with having a manual masking system to allow the current 85" 16:9 and then a movable curtain assembly that will allow you to stretch to a 2.35:1 setup. Can you tell I have thought about this? Hindsight is 20/20 i guess
For the sprayer, I bought the wagner cs DD at home depot on the REAL cheap and LOVE IT!!! It puts the paint out quick but not too bad that you cant compensate for it. I ended up after the screen painting the whole theater room with it as well and while there is some heat buildup, as long as you stay on top with cleaning it out, its perfect (did i mention its cheap?) I plan on using it for many more projects and IMO, not having and additional hose/piece to lug around, it makes moving across whatever surface you are painting THAT much easier
FS: BossoBass A-14K amplifier
beastaudio is online now
post #3 of 95 Old 01-16-2011, 12:58 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Thanks for the reply!
I can't believe I am still up, so this will be quick.
To be more specific about the project, this new screen will be 96"x41". It will be the same height as the 85 inch screen, just wider. I wanted cinemascope pictures to have more visual impact than they can presented on an 85" 16:9 screen.
The frame with hardboard (or something else) idea is based in part on some comments by MississippiMan in the Silver Fire thread regarding alternates to MDF if weight is a concern. Plus, the 85" screen I currently have is Sintra mounted to a wood frame, so I have some experience with this. The difference is that with the Sintra I didn't have to use high levels of pressure to glue something to it in the way I will have to glue the mirror to whatever I put on the frame. Which is why I am considering alternates (that are more rigid) to hardboard as the base for the mirror.
I have been told by more than one person locally that 1/4" MDF "curled" on them over time, so I don't know if I would trust it without a frame.
With regard to glueing the mirror directly the wall, I want to be able to take it with me if I ever move. More important than that, it would take GALLONS of mud to level the wall this will be mounted on.
post #4 of 95 Old 01-16-2011, 02:35 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2027 Post(s)
Liked: 897
I can't believe I'm up so early!
I would strongly suggest using a 98" x 48" x 1/4" sheet of SINTRA again as your Substrate. It's ability to accept paint directly also lends itself to adhesive.
Cut 3" off the Top to create a 45" high sheet. Take the 3" x 96" strip and cut it down to 2- 45" pieces.
Glue the Mirror to the 45" x 96" Sintra, centered between the 45" height. Use a "Adhesive Caulk" like White Lightning or similar Poly-Acrylic. Let the adhesive dry overnight.
Attach the assembly to the wall using Drywall Screws ran through the 3" border.
Attach the 45" x 3" "wings" on each side in the same way.
Mask off around the Screen starting at the edge of the Mirror all around.
Spray away.
Build & apply your 3.25" Velvet Wrapped MDF Base Screen Trim directly onto/over the Sintra Borders, butting the edges of the Trim against the edge of the Mirror using a powered Trim Nailer or hammered-in 1.5" Bright Finish Nails. Set the nails below the Velvet using a Fine-Tipped Nail Set.
As the Beastly One stated, the Wag'ster DD is very multi-use. It does spray paint with a high degree of vigor that requires you to adjust speed to compensate, creating "Dusters" that provide each subsequent coat the tack-able surface needed to hold onto the paint. Heat build-up in the Gun's Spray Head won't be an issue for your smaller screen, but cleaning the Gun after each coat is still highly recommended.
The Gleem No-Name unit is perfectly fine to use as well. Either Gun simply requires you find the best viscosity to allow the paint to flow freely, and then a short amount of practice to familiarize yourself to the "lay-down" properties the Gun produces.
When a Mirror is involved, 2 Dusters and no more than 3 light coats is the suggested amount to apply. If your err in the amount of paint applied, err on the conservative side. Applying more Dusters, or another full coat because you swept through the others too quickly is better to deal with than having to wipe down the runs that come with too heavy an application.
I also suggest that you overlap each row by at least 70%, especially the Dusters. With the newer Electric Sprayers, and their increased rate of flow, it's better to move quicker...create a more "Duster-like" coat where each row's overlap is what fills in the needful areas, not heavier coats. such a overlap also eliminated horizontal bands that come from the areas between the rows being sparser, while the center of the Row gets significantly more paint.
The latter really should not happen if the paint is thinned properly. When you shoot a practice run (...I hate the word "run"...) and then each time you start a coat, also shoot on the masking to the side to check how even a vertical strip your producing...you should with the proper speed and distance lay down very evenly applied coats.
Be advised that the first Duster is not a "covering coat" and will only make the Mirror look "very hazy". The 2nd Duster will fill in a bit more...perhaps to the extent you can no longer see any degree of reflection at all.
By the 2nd full coat you should be looking at a pretty good looking surface. a 3rd lightly applied coat with 70% overlap usually will complete the process.
MississippiMan is online now
post #5 of 95 Old 01-16-2011, 02:53 AM
Liked: 897
I got your PMs, and the reference about the Wagner Plus.
That is the unit I use, and it's even more robust and multi-use a sprayer than the Double Duty. As such, I use the Spray Heads that came with the original Wagner Control Spray...that have smaller needles. Shoot...I even bought two more original Wag'ster CSs' just to have spares!
I had to do that because the "Front End kits' sold now are the DD/Plus heads...not the "Original CS" variety.
Yeah...I have that advantage. . My spray patterns are more fine than the "splatter-y" ones seen posted. But even so I still gotta scoot across the surface least those finer droplets leave me runnin' for a wet rag! The additional pressure output of the Plus make caution and practice all the more essential.
Lastly, the presence of the "Hose" is something to consider on any "Hose-fed" Gun. You have to hold it over your shoulder and/or out at arm's length to avoid stepping on it, cutting off the air pressure, and having the Gun "cough out" a blob of paint. But the Hose-fed units never heat up at the Spray head, and so being, I find it not necessary to break them down to clean them during the "Duster" phase when those ultra thin coats take only 20-30- minutes to dry under good conditions.
I still do clean the Gun when I'm waiting a hour between coats.
post #6 of 95 Old 01-16-2011, 08:04 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Thanks MM!
Let me see if I've got the essence of your points.
I get the idea that without the smaller needles from the original Control Spray, that the Plus is not really a slam dunk (for this application) over the DD or the original CS because it throws so much paint due to it's higher pressure, true?
Does the Gleem no-name throw as much paint? Or do the additional needles allow it to approach the type of spray you get with the Plus w/original needles?
I think I can deal with the hoses, especially if the sprayer in question allows me to throw a finer spray.
Just in case I haven't made it clear, I think my most likely mode of failure is to throw too heavy a coat of paint, especially with the "covering" coats. A combination that approaches yours would seem to be more error tolerant.
I guess the only thing that would give me pause (from a purchase standpoint) would be picking up a Control Spray Plus AND a Control Spray (for the needles) like you did. Not saying I won't, because I have learned that unnecessary scrimping on tools usually bites you in the end. I would have to ponder a bit before making that decision though.
I would love to use Sintra as the substrate, as your suggestion adheres strongly to the KISS principle as well as being extremely light, but so far I can't find a local supply that would allow me to obtain a sheet like the one you describe without incurring HUGE shipping costs. The source I used when I obtained the 4x8 sheet used for my 85" screen appears to have closed up shop.
I'll do some more looking.
post #7 of 95 Old 01-16-2011, 12:29 PM
Liked: 897
Originally Posted by NewGate88 View Post
Thanks MM!
While the Plus is an excellent unit, what it does require is more care and observance as far as speed, distance from the work, and getting viscosity right. But a big advantage is how fast it can get the job done. 2x faster than almost anything else, due to the volume of paint being shot.
No it does not, and a 1.5 mm Needle would be optimal. I think however the Gleem unit has a 1.8 and a 1.0, while the CS-DD and Plus share a whoppin' 2.4 mm thingee.
I know. Ideally, one would purchase both the CS-Plus or DD, and a older CS unit. But that would be asking a lot from those already choosing DIY for budgetary reasons.
Well consider this:
1. You'd have to thin the paint more, and still be just as quick and precise in your spraying technique.
2. Your only extra advantage would be producing a finer spray, and with the greater pressure...a taller vertical spray pattern.
Personally, I think extra practice and familiarization with the unit of choice is your best answer short of incurring the extra cost....because even if you do spend...you'll still need to practice anyway.
The change up, use Brown Hardboard (rough side). Make sure that side is free of dust. Cut as directed before. Apply adhesive in think beads but trowel out to smooth. Carefully "slide-skate" on the Mirror (w/Plastic still on it...) in you stocking feet, and "feel for any lumps and press them out. Let the assembly dry as long as possible.
post #8 of 95 Old 01-16-2011, 06:15 PM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Thanks again MM.
I will probably go with the No-name sprayer, but I'll ponder it. It sounds like the No-name might be the better choice for an inexperienced sprayer like me for THIS purpose. But it also sounds like the CS Plus would be the better choice for almost anything else due to the volume of paint it will throw.
I will continue my search for a source of Sintra. I realized I haven't tried all the local sign companies yet. The shop that is getting me the mirror doesn't handle Sintra, but one of the other shops might.
Which reminds me. For anyone who might be some distance from a distributor of the acrylic mirrors and despairing of prohibitive shipping costs, you might try a local sign shop like I did. They will be getting the mirror with their regular delivery, so I don't have to pay shipping on that big sheet.
MM, I may be looking for some more pointers when it comes to the spraying later on.
Say, would a sheet of TWH make good practice for spraying the mirror?
post #9 of 95 Old 01-16-2011, 06:24 PM
Liked: 897
Since I make actual screens out of TWH, and utilize the shiny, ultra smooth surface as a form of "White Fusion"..... I'd venture to say yes.
So go at it with some care and whoop....there it is. Perfectly good extra screen.
Hey...and you then flip it over, cut it down and glue the Mirror to it.
I'm good.
post #10 of 95 Old 01-17-2011, 12:55 PM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
MIssissippiMan (or anyone else), is there any compelling reason to get the Front End Kit with the CS Plus since the FEK's are shipping with the new needles?
post #11 of 95 Old 01-17-2011, 01:36 PM
Liked: 897
No. Since the size of the needles are the same, all you'd be getting is a "spare", not something that would impart a different spraying condition.
I remember how first I was excited at the prospect of having both be interchangeable, and then how crappy it was to find out a few months later that Wagner had discontinued the original CS FIK. For a while there, everything was just about as perfect a situation as could be hoped for.
That is a reason I have advised many to consider the "No Name" HVLP (Graco) spraying on the Gleem site, since at least it's largest needle is still smaller than what comes with the CS-Plus & CS-DD. Simply put, for those who are trying to get perfection as easily as possible, a smaller needle size combined with the correct paint viscosity helps achieve such all the more easier.
One last possibility is to search for a and purchase the older CS unit if it's priced reasonable. I still do that myself...if I encounter one on the self somewhere...it instantly becomes "mine". Check your local HD/Lowes. You might get a surprise! Otherwise.............
http://www.amazon.com/Wagner-Product.../dp/B000DZBP60
post #12 of 95 Old 01-17-2011, 02:20 PM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Yeah, I am thinking about the CS Plus from the standpoint of it's long term versatility. If I just man up, and use some practice to get used to it I will have a tool that is mo' better at more tasks.
Plus, if I found the right manual on line, the gleem unit looks like a bigger pain to clean.
post #13 of 95 Old 01-18-2011, 06:46 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Wait a sec. I just reread all these posts, and I think I misunderstood something. I have been fixated on the fact that the most accomplished sprayer here uses the CS Plus (but with CS needles). My apologies for being so hardheaded and difficult to get through to MM, but I just realized that you have been telling me(I think) I would be better off with the original CS alone, than with the Plus alone. Maybe even better off than with the Graco alone. Do I have that right?
I can get a CS locally for the same price as the Graco.
post #14 of 95 Old 01-18-2011, 07:02 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Beastaudio, would you have been happier with the DD (for your screen) if it through less paint?
post #15 of 95 Old 01-18-2011, 07:04 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Sorry Beastly, if it THREW (not through) less paint.
post #16 of 95 Old 01-18-2011, 07:32 AM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 57
NewGate88;
the best combination would be to use the DD or Plus with the original CS head unit. the reason being that both those newer units can push more AIR through the smaller head unit... therefore a finer mist can be accomplished than what comes with the larger heads on the new units.
me personally, i only have the original CS, but found it lacking the power to push the metallics through the smaller head unit. i did not want to purchase the DD for the power just to use the CS head units i already owned. fortunately, mine came with an additional head unit.
so i slightly modified one of the head units on my CS from 1.5 to about 1.7. so that i got a fuller, wider spray.
my painting technique, from a different perspective, i look for a 9-12 inch tall spray pattern and i work from about 18-24" from the screen with the same 60% overlap.
there does come a point, in my opinion, when you can dilute this mix too much with water, and it goes from a fine mist to water splatter.
as for the Graco. from the posts i've seen, and not having used it, i get the feeling the Graco is putting out far more paint than any of the wagners. which means less room for error when it comes to viscosity and runs.
pb_maxxx is offline
post #17 of 95 Old 01-18-2011, 07:32 AM
Liked: 897
Hold on...reply being laboriously pecked out....
PB...PLEASE do not suggest that anyone use such a distance.
post #18 of 95 Old 01-18-2011, 07:55 AM
Liked: 897
Well, it's like this.
I used the original CS for some time, and thinned the paint considerably to do so. I achieved almost glass smooth finishes....but I also managed to encounter a few instances of Runs and sagging in the process. Over a short time I realized I had to use a technique with widely overlapping Finish coats applied at a reasonably quick speed to avoid such torment.
Then Came the "Plus"...or rather a even more robust version sold in Australia. I found that one waiting for me there, pre-purchased by a New A/V Dealer. I did cart my own CS with me, but the New Dealer was going to have to make due with the bigger Wagner anyway, so I tried it.
wow.
It delivered so much pressure the Gun actually had a degree of recoil when the trigger was depressed. The spray pattern was at least 14" tall! I was overjoyed at how quickly it got the first coat on a 110" Light Fusion Mirror screen done. Say, like well under a minute!
Yes, I was tickled pink.......until I came back 10 minutes later and saw a veritable waterfall of 12" long runs cascading down the entire length of the Screen. In fact, several layers of them, each representing an individually painted horizontal row.
I felt first like a complete idjit...then I got depressed because I had traveled almost 9000 miles and it looked pretty hopeless to get much of anything worthwhile accomplished. Australian Beer is good...but it's no compensation when one is considering slashing one's own wrists!
But I settled down and reasoned it out. I "washed" the paint Mirror off, and went at it again, this time increasing my distance out to 14"-16" and moving at 3' sec.
The "Duster" coat was born!
Then I thought..."Hey...why is this thing such a "Dump Gun" of a HVLP? I then noticed that the size of the needle tip was MUCH larger. Where the original CS came almost to a barely blunted point, the CS-Fine Spray looked like the end of a slightly used Crayon !
I noted that the Front End connected just the same way as my own CS, so I exchanged them...and what a difference!
But even then I had to still allow for the extra pressure...and not go nearly as slowly as I had to with the original CS.
I came home, bought a CS-Plus, another CS Front End Kit (...I left my other one in AU for the Dealer to use....) and from that point on counseled anyone interested in purchasing a "Plus" to also get the older Front End Kit.
That worked out well until the Double Duty came out, then Wagner discontinued the original FIK, and started phasing out the original CS as well.
So there it is...the History of the Wagner CS as lived by MississippiMan.
Now back to the present.
  • Using the original CS, you must add water until you approach almost 30% water to Paint mix volume. That's a lot...but required to get the pattern up to 12" from 14" away.
  • At that viscosity, it becomes required to move no slower than 2' per second when applying a "Finish Coat".
  • With the CS-Plus, water content can be less by about 25% (24 0z max)
  • You must "Duster" any surface first...preferably at least 2x before trying to apply a "Finish level" coating. And "Finish Level" coatings still need to be applied at 2' per second from 12" -14", or 1' per second from 16"
  • When you are getting a 12" tall pattern, a 60%-70% overlap means you only drop the Gun down 4" to start another row.
  • Using the Original FIK on a CS-Plus only means you will have a smoother finish, more Glassy-like...rather than it looking like a Finish Foam Roller applied coat.
  • The Graco (No Name) only requires that you apply the paint with the same procedure as you do using a CS-Plus or DD. Only with the Graco, you can get/exchange needle sizes.
The CS-Double Duty can do an excellent job used under the aforementioned parameters.
If you get the Original CS...you must instead thin the paint almost more than you think reasonable, and then practice to see how much and how well it's laying down. That is the only safe way to go about it. But without a doubt, the original CS is a good choice to use...so if that is your choice, you'll get a fine screen for the effort.
All in all, using any version of the Electric HVLP Guns represents a far less expensive proposition than standard HVLP rigs. And in any case, with the conventional Rigs, you still must thin the paints, and use 1.5mm needles if at all possible. I started out using 2.2mm needles with my big rig, and 45 psi at the Gun. I DID NOT thin the paint at all. So my first screens had a very "Sand Papery" texture.
If you spray from too far away, and/or move too fast, that is what kind of finish you will wind up with as well. It's not really desirable even if it looks perfect, mostly because the surface will not suffer any cleaning well. Wiping or rubbing can and will smooth out the texture and leave you with a "shiny spot" that while not noticeable when projecting an image, is quite apparent when the Screen is viewed under room lighting.
Summery:
No matter what Gun you use, there exists a method in which to use it properly for the application. And practice does help to make perfect.
post #19 of 95 Old 01-18-2011, 08:02 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Would it be fair to say the Graco is the one sprayer that can most closely approach the glassy finish you can get with the CS Plus/CS FEK combination?
post #20 of 95 Old 01-18-2011, 08:10 AM
Liked: 897
With one using a smaller needle.....yes. Otherwise it's purely a cost and availability consideration between the Plus and it. If one is doing a BIG screen, or wanting to use the Sprayer for other projects where the paint will require less thinning...the Plus is the best one overall.
On the other hand, if one wants versatility in a single sprayer, the Graco, with it's interchangeable needles is an excellent choice...and becomes almost an irresistible one at just under $50.00
Beyond/past that...the CS-Pus w/ a CS Front End is still a World Beater. When the Gracos' are all gone, there will again be only two Players on the Field...the CS-DD and the CS-Plus.
post #21 of 95 Old 01-18-2011, 09:46 AM
Point Source
beastaudio's Avatar
Liked: 3308
I was actually thrilled with the output. the trick was too not thin it TOO much as is necessary for the regular CS. ended up doing the whole room after the screen with the DD and with the right viscosity, paint goes on smooth as Butta.
post #22 of 95 Old 01-18-2011, 10:22 AM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Graco ordered. Most affordable (about even with the original CS), the option with which I am most likely to succeed initially (save buying TWO guns; a Plus and original), and still useful for other tasks.
Beastly, the cheapest I found the DD was about $30 more than the Graco, and the Graco sounds a little more Newbe friendly. Although from your comments it sounds like they might be close.
Thanks guys, for the exhaustive and informative replies. I am going to chew on the discussions about painting technique, and do a little review of some other posts to see if I can resolve some remaining questions about the technique to strive for. I thought I had a good grasp of what I needed to attempt, but some recent comments have seemingly contradicted what I THOUGHT I knew.
I found a local sign shop that routinely handles Sintra, so there is a 4'x8'x1/4 sheet on the way from his supplier, which the sign shop will cut for me.
One thing I have not seen discussed (probably has been somewhere, and I just missed it) is just how much of the room needs to be masked or covered with drop cloth with this kind of sprayer. Do I need to try to completely enclose the area in which the spraying will be done and/or cover the whole room with drop cloth? Or is the overspray so limited that something less extreme is called for? I have noticed promotional photos of people spraying cabinets with these things with nothing but a breathing mask for room preparation.
post #23 of 95 Old 01-18-2011, 10:35 AM
newB24's Avatar
I masked off a very large area, I won't know if I did enough or too much until I get the masking down.
I will say that once I was done spraying a coat, there was a haze in my entire basement. I left my respirator with disposable disks on for a while and opened some windows while I cleaned up after a coat. I covered just about everything in site with plastic to protect it.
newB24 is offline
post #24 of 95 Old 01-18-2011, 12:13 PM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
Newb24, which sprayer did you use?
post #25 of 95 Old 01-18-2011, 12:43 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 57
given the pics of the graco coats... and the striping that i'm seeing... actually i would suggest about 16-18"... though maybe stay away from the 24" unless you are doing some really light dusters. the pics also suggest not as much overlapping is happening either.
i adopted the technique due to the fact i needed to do super fine and smooth dusters for rear projection.
oh by the way... saw some original control sprays in the chicago area this weekend... $68
pb_maxxx is offline
post #26 of 95 Old 01-18-2011, 05:20 PM
newB24's Avatar
I did the Graco, Gleem no name.
At 14" distance, my spray was only about 8". I put tape on the floor to help me stay the right distance.
I'm sure PB is talking about my application, I could not come close to getting the proper overlap, I was too scared after that first run but I really tried. I just couldn't trust myself. I feel like I can see some striping in my application so that just confirms it.
If I can relay any advice, find something real to practice on and get your technique down and get a lot of light on your surface so you can see that paint hitting the screen. Perfect that Mississippi shuffle and handling the hose so you don't trip and keep going smoothly
newB24 is offline
post #27 of 95 Old 01-18-2011, 06:04 PM
newB24's Avatar
I just took down my plastic, I would say I went a bit overkill but for how easy it goes up and how easy it goes down, can't hurt!
newB24 is offline
post #28 of 95 Old 01-19-2011, 02:44 PM
Point Source
beastaudio's Avatar
Liked: 3308
yea, dont do that. I would seal off the room pretty good and get something at least on the wall you are using to paint the screen and the floor. I noticed that while most of the paint that flies around the room is dry by the time it sticks to anything, its still a Bia to clean off anything it settles onto. just get some thin ply plastic and some of the paper roll to cover the floor and you are good to go. When i did the whole basement, the dust even traveled up the steps and got on the floor of the room above!! crazy!
post #29 of 95 Old 01-30-2011, 02:31 PM - Thread Starter
NewGate88's Avatar
Quoted: 18 Post(s)
I need to clear up some details before I start execution of this project.
When it comes to mixing the paint I saw MM mention initially using only half the listed amount of the Folk Art champagne gold, and adding more only if the color of the mix doesn't look right. Is that still the case?
I am also still a little foggy on determining the proper viscosity of the paint. Are we talking about getting it thin enough that you can pour the paint through the strainer (say an old #2 pencil size stream?) without the paint backing up and overflowing the strainer?
When doing my practice sprays can I use some other paint (rather than waste the Silver Fire), just as long as I get it to the same viscosity? Or is there some special property of the Silver Fire when sprayed that means I should use it for practice? I have some Rustoleum Metallic silver around here somewhere I thought I would use.
Is there any risk of the mirror separating from the Sintra base if I spray it in a different location than it's final location, then move it after painting is complete?
I will be using the Graco sprayer. After perusing the Graco (spray-station) website I learned I can order 1mm and 1.5 mm needles and tips. Spraying is not going to commence until I have a 1.5mm or 1 mm needle in the gun (it shipped with a 2mm needle). MM, in an earlier post you stated that a 1.5mm needle would be ideal. Is that still true? And if so, why is the 1.5 mm needle better than the 1mm? Is it that the finish with the 1mm needle might be too slick, resulting in a surface that produces glare?
I am still a little confused about the technique to strive for. My understanding of a Duster coat is to spray from 12 to 14 away at ~3 ft. per second with about 70% overlap. My confusion is what to do for the finish coats, because I have seen MM talk about doing finish coats at 3ft./second. So should my finish coats be a just a little slower, say about 2 ft./second? Or the same speed as the dusters with more overlap?
I suspect my confusion lies with reading recommendations that have differed because they were given at different times with different guns in mind, but I just want to be sure before I start.
post #30 of 95 Old 01-31-2011, 06:35 AM
Liked: 897
The FACG is specifically for creating warm Flesh tones. If a Mix appears ever so slightly tilted toward Blue-Gray, introducing a light colored Gold helps remedy that. But recently I have found that with the latest mix increments, less has been needed. And adding too much can shift the Gray shade into a vague "Browni-ish" tint...and you don't want that. So adding it in when necessary and incrementally is always better than just dumping it in all at once. If it's needed, and you add some and stir, you can see the Gray cange immediately, so by adding it slowly you can easily avoid any reverse issues.
A "Pencil thick" pour stream is a little to little. More like the rate you'd use how you would pour milk slowly into a smaller glass.
Any normal consistency Latex paint (water based) will do. I'm not so sure the Rustoleum is water based.
Not if it is adhered well and left to dry completely before you start moving it about. Also, avoiding flexing it too much (bending) is a good idea. The most important thing is to use enough adhesive, and spread it out evenly, then after laying down the mirror like you would a "Decal", gradually from one side to another to avoid trapping air underneath, you then carefully press down and "skate" on the surface in y6our Stocking Feet, using your foot's tactile touch to feel any lumps of adhesive and therein flatten and spread them out.
1.5mm is ideal. With a 1.0 mm Needle you'd have to thin the paint all the more, and your pattern height would be smaller. With such thin paint, and a reduced row size/width, the job would take longer, overlapping would be harder, keeping the smaller rows straighter would be more difficult, and because of all of the above, horizontal stripe-ping might be hard to avoid.
Finish Coats @ 1.5' - 2' second at 12"-14" with same overlap. Speed always is related to viscosity. If the mix seems very loose, and is applying quite readily during the Duster-phase, doing the initial Finish Coat at a higher rate of speed is always going to be safer, and as you build up the paint coating, the next coat can always be put up a little heavier (within the stated 1.5" sec. limit of course)
I'm glad you asked, although when this Post popped up on my Phone while I was "beached" it did make me sigh at the prospect of the needed
long" reply. Oh well, I do make my own Bed on here, don't I?
Reply DIY Screen Section
