The Official Silver Fire V.2 Thread. - Page 54 - AVS Forum
 2Likes
post #1591 of 1603 Old 09-24-2014, 01:08 AM
Liked: 0
Check your spray gun, that the needle tip is not blocked or maybe check what spray setting you have the gun set to.
mediahomesireland is offline
post #1592 of 1603 Old 09-24-2014, 06:06 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
thanks for the tip, I think i figured out the problem.
narhic_fd is offline
post #1593 of 1603 Old 09-27-2014, 05:14 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
Are the Wagner control spray and double duty still good guns to use even though they come stock with the 2.0 needle instead of the original 1.5mm needle?
post #1594 of 1603 Old 09-27-2014, 05:19 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
Is the Wagner control spray and double duty still viable choices for spray gun even though they now come stock with 2.0 needle?
post #1595 of 1603 Old 09-27-2014, 05:41 PM - Thread Starter
AVS Club Gold
MississippiMan's Avatar
Quoted: 180 Post(s)
Liked: 233
Haven't ya asked this same question at least 19 times before?
Don't answer....it's been at least 12 times.
If you try / do use those larger size needles, a "Duster" becomes a rapid sweep across the screen. At least 2x faster than when using a Graco with a 1.5 mm Tip.
You don't get crazy because the droplets look like splatters either.
You just fly though a coating....let it dry....do it again...and continue doing it over and over until you fill in all the surface evenly.
Every initial S-I-L-V-E-R I sprayed was done using the original Control Spray (2.0 mm Tip) And the only way it could be / was successfully done was by doing very rapidly applied coats.
The Double Duty has a 2.2 mm Tip, and when I used that Gun I ALWAYS used the original 1.5 mm Control Spray Head. I also did likewise with the Control Spray Plus & Max Turbines...and these days I use the CS Max w/a adapted Hose so I can use the Graco 2900/3500 Heads with a 1.0 mm needle.
I do not...have not...would never use the 2.2 mm needle assembly. At least not since the very first couple of screens I sprayed using MMud undiluted. The result was a very coarse, almost sand-papery surface. And a absolute TON of over spray.
Let that be the final word on the matter.
Please.
To quote James T. Kirk;
"I'm laughing at the superior intellect"
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
MississippiMan is offline
post #1596 of 1603 Old 09-27-2014, 06:17 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
We've Went over about the guns..yes, but I had come under the conclusion that you didn't want to use them because of the bigger needle size. The reason I'm asking is after all this time and all the problems I've had it was due to a faulty turbine. I've known for a bit that something was off when I was spraying some normal latex paint. It didn't seem to be quit as smooth as I re all it. Well..when I tried to spray some semi gloss or gloss the paint was coming out horrible. I couldn't turn the paint flow dial past 30 clicks without it spitting BAD! For some reason it wasn't atomizzing the paint correctly. And before anyone ask..yes i have checked everything and done everything possible to fix it...over and over. So, need to buy another system..nongraco. I did consider the wagner maX but it's a tad pricey. I don't know I might just get it. What is your best recommendation on this price wise?
post #1597 of 1603 Old 09-27-2014, 08:12 PM - Thread Starter
AVS Club Gold
Quoted: 180 Post(s)
Liked: 233
Least expensive workable option:
http://www.amazon.com/Wagner-0417005.../dp/B000DZBP60
.....or get this Combo w/a "Detail Head"
http://www.amazon.com/Wagner-0518080...x+HVLP+Sprayer
http://www.amazon.com/Wagner-Detail-...FF3BVX92D1N2PT
post #1598 of 1603 Old 09-27-2014, 09:16 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
I had discussed this product before but I think I'll get the wagner optistain plus shown here:
http://www.lowes.com/pd_561012-97-05...tain&facetInfo=
it seems to be the wagner control spray rehashed in a slightly diff way...Pretty sure the needle is 2.0 mm.
WOW! Is the detail head a smaller needle then the standered 2.0??
post #1599 of 1603 Old 09-28-2014, 09:02 AM - Thread Starter
AVS Club Gold
Quoted: 180 Post(s)
Liked: 233
WOW! Is the detail head a smaller needle then the standard 2.0??
It certainly should be, and the difference is obvious.
post #1600 of 1603 Old 09-28-2014, 12:34 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
saw this at homedepot:
http://www.homedepot.com/p/Wagner-Pa...specifications
It appears you can buy the detail tip and attach it to this spray station as well. Would it work??
post #1601 of 1603 Old 09-28-2014, 03:39 PM - Thread Starter
AVS Club Gold
Quoted: 180 Post(s)
Liked: 233
It is not of the same power as the Max, nor does it have adjustable pressure at the rear.
With both being the same price, the Max becomes a No Brainer choice. And most likely through Amazon you will pay no Tax.
post #1602 of 1603 Old 09-28-2014, 04:02 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
You were talking about a adapter so you could use the graco gun with the wagner control max, How did you do that???
post #1603 of 1603 Old 09-28-2014, 04:20 PM
narhic_fd's Avatar
Quoted: 13 Post(s)
okay...I got the wagner control max. Thankfully had some Amazon reward points so was a little cheaper. Also, the current thickness of my silver fire is for a lesser power unit...How will I deal with that with the control spray max that pushes more air out??
Reply DIY Screen Section
User Tag List
