The Official Silver Fire V.2 Thread. - Page 75 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #2221 of 2235 Old 06-29-2015, 08:33 AM
merkaba's Avatar
Quoted: 105 Post(s)
look awesome...quite a bit darker than mine for sure. I wish i could see this in person.
merkaba is offline
post #2222 of 2235 Old 06-29-2015, 09:38 AM - Thread Starter
DIY Grand Dad (w/help)
MississippiMan's Avatar
Quoted: 804 Post(s)
Liked: 415
Well....you have those gosh darn "Floods" shining directly down onto both front corners of the screen. The SF accepts and reflects such direct lighting, so it's going to look brighter.
Note the difference in the upper triangular area at dead center that lies just outside the umbra of the Can Floods. Take the same picture with those nasty things turned off, and take it from the distance you took the other shots and I bet it will be much more comparable.
To quote James T. Kirk;
"I'm laughing at the superior intellect"
http://www.invisiblestereo.com
MississippiMan is offline
post #2223 of 2235 Old 06-29-2015, 09:41 AM
Liked: 0
There's probably a lot of perceived difference in shade due to the background wall color.
I will say that the pic I posted is true to the actual color on the board
h0b0 is offline
post #2224 of 2235 Old 06-29-2015, 09:51 AM - Thread Starter
Quoted: 804 Post(s)
Liked: 415
Originally Posted by h0b0 View Post
Don't forget that this is 5 dusters of N/C on to a base of sanded SF V2.5 3.0. It is possible that due to the base of SF 3.0 the N/C may appear darker.
Oh my, absolutely. The darker base will most assuredly deepen the color, and also reduce gain to at least some small degree.
Besides that, the N/C works out to be close to the same shade as the older 2.0
The projector is a $200 Epson 6100 with a $50 lamp after the original Epson one exploded after 700 hours. (only abut 5 of those in my house after I purchased the projector)
Wow. Just 18,000:1 Contrast and only 1800 lumen too. Kinda mind-blowin' to think what a Epson 5030 or a Panny 8000 would put up.
Your future looks pretty bright....better get some good
Gotta luv 'dem $50.00 lamps!
post #2225 of 2235 Old 06-29-2015, 10:17 AM
Movie78's Avatar
Quoted: 319 Post(s)
Liked: 53
What kind of SilverFire N/C mix did you do?
Rustoleum Metallic Accents – White Pearl 24 oz.
Rustoleum Metallic Accents – Sterling Silver 16oz.
Behr 1750 UPW Flat 16 oz.
Rustoleum's Ultimate Polyurethane Matte Finish (water based) 16 oz.
Distilled Water 32 oz
Movie78 is online now
post #2226 of 2235 Old 06-29-2015, 11:43 AM
Liked: 0
That is the mix I used. Very quick and easy to make up. My base though is SF v2.5 3.0 so results will vary. I only had the base up because I had my Wagner 590 set to fire hose and I messed up my original attempt so I sanded it back.
h0b0 is offline
post #2227 of 2235 Old 06-30-2015, 10:53 AM
Movie78's Avatar
Quoted: 319 Post(s)
Liked: 53
I have an extra
Rust-Oleum Metallic Accents Interior Gloss White Pearl
Rust-Oleum Metallic Accents Interior Gloss Sterling Silver Metallic
PM me if you interested.
post #2228 of 2235 Old 06-30-2015, 12:49 PM - Thread Starter
Quoted: 804 Post(s)
Liked: 415
I have an extra
Monitor the Threads and PM whomever seems a likely prospect.
post #2229 of 2235 Old 06-30-2015, 01:12 PM
Movie78's Avatar
Quoted: 319 Post(s)
Liked: 53
Good idea.
post #2230 of 2235 Old 06-30-2015, 07:08 PM
Movie78's Avatar
Quoted: 319 Post(s)
Liked: 53
Got all the item necessary to paint, but i am a little bit nervous.
This is my first time spray painting.
Spoiler!
Spoiler!
post #2231 of 2235 Old 06-30-2015, 07:42 PM - Thread Starter
Quoted: 804 Post(s)
Liked: 415
Yucky mixing tool.
Home Depot has this, usually in stock in the Store I believe, and it is much more effective.
http://www.homedepot.com/p/Workforce...M1HD/202251542
The metal one there doesn't stir thinner paints as well as it does the thicker paints it was designed for. It must be run at a faster speed with thinner paint, and that is exactly what you do not want to do with Silver Fire because it whips in air and creates tiny bubbles. The metal can also scrape the Teflon off the sides of that can you have there. Change it out if you can.
Oh how I miss "The Squirrel".
post #2232 of 2235 Old 07-01-2015, 05:57 AM
Movie78's Avatar
Quoted: 319 Post(s)
Liked: 53
Yucky mixing tool.
Just got the Workforce 1 gallon from HomeDepot.
Time to mix the paint.
post #2233 of 2235 Old 07-01-2015, 07:30 AM - Thread Starter
Quoted: 804 Post(s)
Liked: 415
Set the Drill on slow speed, and mix for 2-3 minutes. It's a good thing to first add the Water and Poly, then the silver and pearl....in that order.
All the time mixing slowly.
post #2234 of 2235 Old 07-01-2015, 08:39 AM
Movie78's Avatar
Quoted: 319 Post(s)
Liked: 53
In Order
Distilled Water
Poly
Silver
Pearl
Behr 1750
Is that correct?
post #2235 of 2235 Old 07-01-2015, 05:12 PM - Thread Starter
Quoted: 804 Post(s)
Liked: 415
In Order
Distilled Water
Poly
Behr 1750
Silver
Pearl
Is that correct?
Do it in the order above
Reply DIY Screen Section
