The Official Silver Fire V.2 Thread. - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #2461 of 2469 Unread 08-22-2016, 09:02 AM - Thread Starter
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1526 Post(s)
Liked: 684
Originally Posted by rayians View Post
Many thank you's MississippiMan! Would you recommend the same 1.0mm spray guns for priming?
You can use it, by starting with the thinner Kinsser 123, and further thinning it with water until it strains freely at a slow pour through a Bag Strainer.
It will require at least 3-4 coats, (4 coats is best) but they are Dusters, and will dry very quickly. Sand lightly after the next to last coat for a ultra smooth primed surface.
MississippiMan is offline
post #2462 of 2469 Unread 08-24-2016, 08:44 AM
rayians's Avatar
MississippiMan, do you recommend sanding the painted screen at any point, maybe before the last 1 or 2 coats?
rayians is offline
post #2463 of 2469 Unread 08-24-2016, 07:45 PM - Thread Starter
Liked: 684
Sometimes during the Dusting process, a slight amount of coarse texture can happen (feels slightly "sand-papery" like) This usually happens because the Gun is being held too far from the surface (12" to 14" is the maximum distance)
On / about the 5-6th coats, the slight texture can be eliminated by sanding very lightly over the entire surface. The object is not "removal" but "smoothing".
Wipe or Dust the screen surface clean with a soft cloth, and apply 2 Dusters.
post #2464 of 2469 Unread Yesterday, 06:40 AM
rayians's Avatar
Starting the priming today, will post pics when it's all done!
rayians is offline
post #2465 of 2469 Unread Today, 12:52 PM
narhic_fd's Avatar
Quoted: 72 Post(s)
I recently bought a 3200 lumen projector called Optoma DH1012. A projector that has 1000 lumes more then my previous projector. I decided to make up a test sample of Silver Fire 5.0 to see how it looked. I made the sample to specs but added an extra 3oz Behr UPW. Now, I only made a quater batch but i took extra care at scaling down the measurements to equal the correct amounts.
6 oz rustoleum white pearl
6 oz rustoleum silver
4 oz rustoleum ult poly matte
3.25 oz Behr UPW
1tbs + 3/4 tsp liquitex gold
plus colorant and water needed to spray
I sprayed only 3 coats on white covered surface but it has a grainy look to it. I imagine that the higher lumens contribute to seeing more graininess but suprised at seeing it in only 3 coats . What could be giving it such a grainy look from the mica?? Can to much water in the mix be the prob??? The higher lumens?? What?? What would a personalized Silver Fire 5.0 reciepe for my projector be that would lessen the grainy look?? Thanks.
narhic_fd is online now
post #2466 of 2469 Unread Today, 02:19 PM - Thread Starter
Liked: 684
Too few coats. 3 Coats is 4 coats too few. You cannot get a smooth look with a freckled surface.
Try 8 oz Pearl and 4 oz Silver w/2 oz UPW
You should not need the Gold when using RustOleum Metallic paint, but doing so can add a bit warmness to Skin Tones, as well as help the darker 5.0 Gray hue be more neutral. Add it sparingly though. There is Gold already in the Colorant.
post #2467 of 2469 Unread Today, 02:42 PM
narhic_fd's Avatar
Quoted: 72 Post(s)
Now when you say 2 Oz of UPW you mean it in the quater batch correct?? 2 oz of UPW in 1/4 batch and 8 oz if doing full batch.
post #2468 of 2469 Unread Today, 05:04 PM - Thread Starter
Liked: 684
Of course....I tailored my response to fit your example.
post #2469 of 2469 Unread Today, 06:15 PM
narhic_fd's Avatar
Quoted: 72 Post(s)
How much liquitex gold??
Reply DIY Screen Section
