Moving Projector to basement - Help please? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-24-2011, 11:51 AM - Thread Starter
lookout321's Avatar
Hi guys. looking for some advice.
I'm moving my Panasonic AE-900u to the basement after 4 years. It was in my den but even with an original Silver fire 110" screen on drywall it still was not bright enough for daytime viewing.
In my basement I will be sitting ~10-12 feet from the screen which I would like to be 110" again since I have a nice velvet-wrapped frame ready to go.
With full light control, could you guys offer some advice/suggestions on which paint mixture you would suggest for my situation/projector. My projector only has ~600 hours on the original bulb.
Thanks guys!!! I want to use this for movies, video gaming, and feeding internet video sources via a computer via HDMI.
Matt
lookout321 is offline
post #2 of 5 Old 04-25-2011, 05:57 AM - Thread Starter
lookout321's Avatar
No help anyone? MMan, any suggestions for my older panasonic projector's specs?
post #3 of 5 Old 04-25-2011, 06:02 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2049 Post(s)
Liked: 907
Hi!
RS-MaxxMudd LL for a rollin' job. Silver Fire v2 2.0 if you can spray and you want better contrast performance. Since you've already been viewing on a SF Screen,
I'm hoping that spraying is still an option for you.
SF v2 2.0 is a very light shade of Gray that is very bright (1.2 gain) but retains significant contrast enhancing properties. In a Light Controlled setting it will serve your older Panny with distinction.
MississippiMan is offline
post #4 of 5 Old 04-25-2011, 11:43 AM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 57
silver fire v2 is a couple shades light in color than the original silver fire.
as a point of reference... a silver fire v2 3.0 screen is slightly lighter in shade of color than silver fire 1.75 is.
pb_maxxx is offline
post #5 of 5 Old 04-25-2011, 03:10 PM - Thread Starter
lookout321's Avatar
Thank you guys for the help. I'm looking forward to a new screen in the basement!!!
Reply DIY Screen Section
