Best paint for gaming curved screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-11-2011, 10:41 AM - Thread Starter
julian bernard's Avatar
Hi all,
I'm just about finishing off my screen (constructed out of plasterboard) which has a radius of 2 metres and is approx 6 metres long.
Ambient light is not an issue as the room is completely sealed off from the outside world, and I shall be using 2-3 Projectors, each projecting an image of roughly 2.2 metres wide from a throw distance of >3.4 metres. The pj's are Mitsubishis HC4000.
Any advice on what road to go down regarding gain, application and methods to avoid hotspotting.
Kind regards,
Julian
P.S. I am relatively new at projector paints!
julian bernard is offline
post #2 of 14 Old 05-11-2011, 11:08 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2161 Post(s)
Liked: 975
Quite an undertaking. What software are you using to blend the images?
MississippiMan is offline
post #3 of 14 Old 05-12-2011, 12:12 AM - Thread Starter
Warpilizar, toicope with both edge blending and distortion.
post #4 of 14 Old 05-12-2011, 06:38 AM
Liked: 975
OK...then for certain you want exceptional contrast, as that allows you to see almost infinate shadow detail. That's REALLY important so you can spot indistinct "Heads and Body Outlines"
Use Silver Fire v.2 2.0.
You will be mightily feared among your Peers.
post #5 of 14 Old 05-12-2011, 03:19 PM - Thread Starter
Hmmm silver fire sounds interesting! What do you mean by my peers will fear me hehehe?
post #6 of 14 Old 05-13-2011, 03:27 AM
Liked: 975
You will be at the top of all the Leading scoring boards, and others will clamor for you to be on their teams.
Get a real job, a Bum!
post #7 of 14 Old 05-16-2011, 03:19 AM - Thread Starter
Sounds good! What do you mean in the Silver Fire forum when you say...
'SF v2 1.0/1.5/2.0/2.5/3.0/4.0/5.0 on to ad nausea-um'?
Also do you think I'll have any issues with motion sickness as I will be at the centre of the semi circle and hence 2 metres away from every point on the screen?
post #8 of 14 Old 05-16-2011, 03:45 AM - Thread Starter
P.S. would it be ok to apply with a roller (not too good with spray guns!)
post #9 of 14 Old 05-16-2011, 04:49 AM
ERuiz's Avatar
Quoted: 566 Post(s)
Liked: 179
Julian, SF can only be spray painted. If you insist on rolling, then you would have to go with a RS MaxxMudd LL mix. But personally, I would suggest you give spray painting a try. Once you get it right, the results are amazing!
BTW, what type of gaming you do? PC? FPS? Flight sims?
FOR SALE: Sony HW40ES / BIC Acoustech PL-200 sub
LG 65C7P / Denon AVR-X4300H / Klipsch RP-280F / Klipsch RP-450C / Klipsch RP-150M (x4) / Klipsch RP-140SA (Atmos) / HSU VTF-3 MK5 DualDrive / PS4 Pro / Oppo 203 / Logitech Harmony Elite
ERuiz is online now
post #10 of 14 Old 05-16-2011, 09:57 AM
Liked: 975
Those numbers refer to the amount "in ounces" of SF Colorant that is added to the Reflective Base / Viscosity Base Mixes to achieve a particular shade of Gray.
Well, if your prone to such...that may well might do it.
Just knock back some Dramamine and have at it!
And BTW, what with your sitting so close, you would be best advised to spray and try to get the most perfect finish you can.
Get this "El Cheapo" HVLP Rig. It's the BomB for the money you spend for it...which ain't a whole 'ell of a lot.
http://www.gleempaint.com/noname.html
post #11 of 14 Old 05-16-2011, 03:01 PM
bane126's Avatar
I needed help determining that too. I plan on getting the materials this weekend and spraying in about a week. Moving at the end of the month so I don't want to build the screen and risk messing it up during the move.
bane126 is offline
post #12 of 14 Old 05-16-2011, 09:12 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 57
where in illinois are you moving to?
pb_maxxx is offline
post #13 of 14 Old 05-17-2011, 03:20 AM - Thread Starter
Yeah I think I 'll pluck up the courage and give spraying a go. I'm currently having a bit of difficulty sourcing the ingredients in the UK to make my SF
post #14 of 14 Old 05-17-2011, 07:25 AM
bane126's Avatar
Just signed a 6 month lease to stay in Elgin for a little longer. Just got married and started a new job so I don't want to make any big moves at the moment, but one thing is for, we have to move out of my parents home. LoL.
bane126 is offline
Reply DIY Screen Section
